Steam distillation
- jedneck
Re: Steam distillation
Just had an idea. Instead of using the steam jet to stir the mash up, why not use an upside down funnel to give surface area to radiate the heat with the steam bubbling out the edge. Would seem to be safer than trying to restrict the steam to increase velocity.
big help
Dunder
big help
Dunder
Jed I think that and the spiral posted on the last page are both good ideas. They will do most of their heat transfer through the copper pipe and should keep pressure down. Your cone design looks like it would create some pressure over a straight pipe though. If the steam is trying to displace that much area it seems like the pressure would be more to do so. But, if you think about it, a long coil of pipe when filled with steam would also displace a lot of water (mash).. I think I was too drunk last night to be commenting about that this early in the morning today.
- jedneck
Here is the next experiment. I just rooted the junk bid and found a piece of sheet and an old 1-3/4 reducer. There is a strand of 10g wire rolled into the lip for strength. It just slips onto the 3/4 inch down pipe. It will also do double duty as a funnel.
big help
Dunder
big help
Dunder
- FreeMountainHermit
The problem is the thick mash doesn't heat evenly. And that's an understatement. If it was liquid, convection currents would stir it.
The thick mash will get boiling hot near and above the injector, then the steam bubbles will rise and break the surface before giving up it's heat.
Now there are two problems. The mash isn't heating uniformly and the alcohol vapor is diluted by the escaping steam bubbles.
How do we work around the problems?
The first and simplest idea is to make the mash thumper tall, skinny and insulated.
The rising steam would heat everything above it uniformly.
The down side is tall and skinny doesn't hold much.
There are small scale commercial versions of this. They are built to fill and empty quickly.
Just realized I have several 5 gallon korny kegs left.
This experiment might take a change in direction.
- Truckinbutch
I'm beginning to lean toward a double boiler setup for cooking and stilling . That's how my Momma cooked up a batch of cornmeal mush to keep it from scorching and that worked well . Water bath surrounding the boiler instead of injecting steam into the mash . No pressure issues or condensation overfill . Boil or simmer and replace evaporated off water externally at any point without risk . Just thinkin .......
A double boiler is a good option but has it's own set of problems.
- Truckinbutch
Yea , but they don't involve overpressure and puking do they ?
There's some posts on bain marie stills. Over pressure, venting and a safe working fluid are some of the problems.
- S-Cackalacky
I'm sure at some point there will be an out-of-the-box solution to evenly heating an on-the-grain wash. This thread seems to be getting into brainstorming mode to try to address that issue. What are some of the facts?
We know that the grains restrict the convection of heat that you would normally have in a pure liquid. The heat becomes localized because the liquid is restricted from movement by the presence of the grains. The result is that localized heat up allows vaporization to take place over an extended period of time until the entire body of wash comes up to heat. Until total heat up is accomplished, fores and heads will be released and smeared into the distillate over a longer period of time.
So, the problem is - what to do about getting up to heat more quickly, or how to prevent the early vapors from reaching the condenser.
A light bulb moment - how about a dephleg on the output. That is, reflux the early vapor back into the steamer until the whole body of wash has a chance to come up to heat.
Any other thoughts on this?
- jedneck
SC
I thought about doing that but my primary is on the small side and I would have to shutdown and refill. But I guess that wouldn't be a problem, I was doing that went I started with steam till I got a feel on water usage. I guess I could reflux till secondary is at temp then shutdown and refill then start collection.
I got a leak in the steam supply line I need to fix. If I get it done I'm gonna do some testing.
big help
Dunder
big help
Dunder
- S-Cackalacky
I may be imagining things, but I think I remember someone else, maybe not in the context of this thread, but somewhere, mentioning something about turning the liebig (PC) vertical (pointing up) and using it for temporary reflux. That might also work in this situation instead of a separate dephleg.
- S-Cackalacky
Jed, could you not use your fill port to add boiling water to your primary? Might be a risky business - handling boiling water.jedneck wrote:SC
- jedneck
That was randymarsh. I have a 90 after the union that connects the Liebig to the still head. I'm thinking point it to the ceiling and tie it off for support. When boiler is at temp kill the power and refill primary and drop the Liebig for collection.
big help
Dunder
big help
Dunder
- jedneck
That is what I do but I use hot tap water. Boiler comes back online in a couple minutes. And don't have to handle boiling water.S-Cackalacky wrote:Jed, could you not use your fill port to add boiling water to your primary? Might be a risky business - handling boiling water.jedneck wrote:SC
big help
Dunder
big help
Dunder
- S-Cackalacky
Sounds like a simple solution to a complex problem. Let us know how it works.jedneck wrote:That was randymarsh. I have a 90 after the union that connects the Liebig to the still head. I'm thinking point it to the ceiling and tie it off for support. When boiler is at temp kill the power and refill primary and drop the Liebig for collection.
I think running the rc till the secondary is up to temp is a good option. Here's another.
When running the secondary there has to be some liquid I'm it still. So why not run a false bottom say 3 to 6 inches above the bottom, and have the steam inject into the liquid bath. Allowing it to heat more evenly as a consequence.
Just a thought,
Yak
Just a thought,
Yak
All of these ideas could be made to work. Depending on the individual set up many of these could be useful.
You have to prevent uneven heating with steam or any other heat source. Uneven heating is exactly why a gas fired boiler will scorch grains.
For most steam set ups:
A tall slim boiler, steam at the bottom and heat rises to the top mostly evenly,
Turbulate the mash, through steam pressure or by manual agitation,
Spread out the steam injection points.
#3 might be the easiest and maybe the safest. Lets say your vessel is round and 2 foot wide by 2.5 feet tall (just for example.) If you make a cross shaped injector head with outlets evenly spaced you can eliminate cold spots. This would not need any pressure to do so. If your vessel has a small opening you could make a detachable injector head in a "Z" shape, slide it down into the boiler, then attach to your injector down pipe after it's inside.
The Idea I'm thinking about is having one injector and move it by hand every so often.
The seal and bushing could be made out of a compression fitting and O-ring.
Swivel fittings are relatively cheap.
This design could tri-clamp and fit in a keg bung. A 3/4 to 1" fitting would be needed for the vapor outlet.
- Attachments
- hand stirred.png (5.43 KiB) Viewed 5841 times
- Skipper1953
I use agitators (stirrers) with folding blades at work. I drop an agitator through a 6 inch opening in a 265 gallon tote (IBC). The blades deploy to about 12 inches when the motor is turned on. I also use a mixer that fits through a 2 inch bung hole in the top of a barrel. The blades deploy to about 6 inches or so. I'm not sure you could buy something for our application but you could probably make something quite serviceable based on the design of the mixers I use. I'll add a link to this post after the Packers are done getting their asses kicked.
edit: Aw, hell. Just do a Google search on "folding agitators". You'll get more hits than you know what to do with.
- S-Cackalacky
Just another thought on this - If you turn the liebig upside-down would you need to reverse the cooling water connections?S-Cackalacky wrote:Sounds like a simple solution to a complex problem. Let us know how it works.jedneck wrote:That was randymarsh. I have a 90 after the union that connects the Liebig to the still head. I'm thinking point it to the ceiling and tie it off for support. When boiler is at temp kill the power and refill primary and drop the Liebig for collection.
Bubba found the answer to the problem of uneven heat and it's real simple.
Insulate the hell out of the mash thumper and fill it with a thin mash.
By thin, I mean a mash not thicker than 2 or 3 pounds per gallon.
Is this what I need: BOILER BRASS PRESSURE RELIEF VALVE SET
As the New Year beckons, I want to set the steam rig built. Is this the steam pressure relief valve I should buy? 15 psi?
Or something similar, is this the recommended psi, etc?
NEW 3/4" WATTS 415 BOILER BRASS PRESSURE RELIEF VALVE SET @15 PSI 450 LBS/HR
-Just need something else to build. -
That'll work. Also 6 foot tall manometer made out of clear plastic tubing to keep track of the pressure.
That will let you know when the injector is starting to plug up before it becomes a problem.
Shady:
Where in the plumbing do you connect this tubing? Do you have a pic?
Thanks btw ..
Thanks btw ..
