MichiganCornhusker wrote:I might have missed it, but what is your grain bill? Are you just using cracked corn out of the bag?
I think you are also using some barley malt and rye, how much?
Depending how coarse the crack is with your corn, iodine can be tough to clear even with good conversion. SG 1.055 doesn't sound too bad, just wondering how much grain per gallon.
Also, curious about the bag. If you are planing to use GeoFabric to strain, is the bag just sort of a pre-filter?
Nice to see your progress, good luck with the ferment.
Thanks MCH.... was hoping you might drop in. I am using cracked corn from the bag that I milled in my corona. It does a fairly good job... I mean its not flour or anything but it does make a difference.
The grain bill was a straight wheated bourbon that became a little hodge podge of a little leftover rye and oat as well.
Roughly:
Corn 45#
White wheat: 10#
2 row: about 10#
Malted american rye:2#
flaked oat 1#
Alpha and beta enzymes at about 0.5 ml/lb grain ( I overshot a little due to panic about a large volume)
I started with 30 gallon water and I think with the steam I added about 5 gallons so I'm close to 2#/gallon in the end.
The bag is from my other post:
http://homedistiller.org/forum/viewtopi ... 8#p7418258 and that thing has held up well. That weave reminds me of the paint strainer material you are now working with but I do not know the pore size...small sounds about right.
I was hoping you would say that about the iodine as well.... my feeling is that I am never going to get all that starch converted (I soaked for a day then ran at 190 for 90 min with corn, then all the other grain as well) but the 1.055 I can live with for now. Beersmith calculated my SG at 1.068 and to have about 7% ABV so I think that is fine and I am still above temp and hoping those enzymes are working away.
I will ferment with the bag in place. Bertha has a 1/2 inch spigot on the bottom and i will drain her that way. There is a little grain in the water now just because I can't be completely neat and spilled a hair in there...oh well. My plan was to drain her, hang the bag to get the drippins out and the strain most of the grain through the paint strainer (5 gallon type) .
To remove the yeasties I will use the geotextile thing we talked about from the Best method for separating corn from mash:
It here in the thread:
http://homedistiller.org/forum/viewtopi ... 7#p7419667
That thing cost 99 cents on amazon (the obligatory shipping brought it up to like $6) and that frame fits my barrel well. It came with some openings in it oddly enough but I sewed them shut and it should be fine.
That's where I am..... hopefully by today it will drop to temp and I will stir one more time along with a starch, SG, and pH check. Then pitch and go! So far this thing is going very well and will of course finish the write up as it is available...
