New steam rig and manometer test
- Twisted Brick
When I first joined HD I was intrigued with the versatility a steam rig/thumper could add to a pot still, but dismissed the idea of building one because of the perceived risks. But after learning that a steam rig could be the shortest viable route to rye step mashes and strips, I committed to learning enough to mitigate those risks. Since my current pot/CCVM still is modular, I figured it wouldn't require too many additional components.
So here is a synopsis of what my steam research revealed and what I was able to build. Since more and more guys are embracing steam, hopefully it helps the next ‘stiller answering some of the same questions I had.
The Vessels
From the beginning the plan was to use two half-barrel kegs. The intent is to step mash in my open-top keg and to strip fruit and mashes prone to scorching in the thumper. At one point I want to connect the boiler to one of my short quarter kegs to provide a more manageable reflux column height.
For my thump keg, I had a 6” ferrule welded to the top, and a 2” drain ferrule welded to the side near the bottom. This was so I could run the thumper downtube through my tee, which I already use on my CCVM and retain my vertical riser. And with reducers, I will be able to run either 2”, 3” or 4” columns/risers, plus it will be nice to be able to get my arm into the keg for cleaning.
Thumper Plumbing
I built the thumper downtube and steam wand modular so I would be able to mash/distill in different-sized vessels and try out different wand designs. This steam wand should be fine with cleared washes. I still need to test a braided/mesh stainless wand for thick mashes.
The Manometer
After reaching out to a number of senior HD members experienced with thumpers, it seemed the simplest, most effective PRV solution would be a manometer. The two requirements I had were that the device had to be able to safely dump the contents created by an over-pressure event and hopefully be able to indicate operational pressure throughout the course of a run.
I liked Yummy’s solution, but then, just by chance, I came across a manometer-like apparatus (acting more as an overpressure blow-off tube) that I learned is common in distilleries in Tasmania. They all look like these:
The Vessels
Thumper Plumbing
The Manometer
- Twisted Brick
Re: New steam rig and manometer test
I felt with a few tweaks, this design could be adapted to my boiler and if I could figure out a way to scale it correctly, it could also indicate a stable pressure inside the boiler. So I built one out of ¾” copper and matching ¾” thick-walled borosilicate glass (20") with an ID of 5/8”. I cut off a 3/4" x 1/2" copper reducer to use as a sleeve for the sightglass so the high temp epoxy would not come into contact with any vapor. Some machining was needed for the 1” ferrules, but it all assembles and breaks down quickly with tri-clamps. A friend who builds commercial shell and tube condensers bent the tubing for me.
From input from HD seniors, the blowoff from the manometer should either be directed into a pipe or hose directed away from the boiler, or submerged into a volume of water. I chose to start off with the latter since the chances of a blowoff are minimal as long as the indicating water level in the manometer remains in the ‘safety’ zone.
This exercise was mostly to test the viability of the design, and if the scale worked, apply it to a final stainless steel version. Also, depending on the outcome I could always build a proper manometer with two sightglasses.
This is what the first prototype looked like:
Before testing my manometer, I ran the steam wand in my open-top keg mash tun/fermenter. The steam ejector worked perfectly, clanging and banging before it calmed down and the mash water was steaming away nicely.
The first thumper test was done with 3 gal of water each in boiler and thumper. I could tell from the sound coming from inside the thumper when the thump charge was getting close to boiling. The pressure in the boiler caused the water in the manometer to rise from the middle of the 20” sight glass to above the top of the glass. No water came out, but I knew that if my thumper charge was larger or if it had thick slops in it, the resultant increase in pressure would certainly require more length (height?) in my manometer. For the next test I ended up adding 14” lengths of copper to both columns for a total height of 45”. Ideally, any rise in water level would remain visible mid-sightglass.
The second test I conducted with the added manometer height I charged the boiler with 10 gal (6 gal water / 4 gal of vinegar) since I would need to do a cleaning run anyway. Another 6 gal of water/vinegar went into the thumper. Once the thumper came online, the water in the sight glass rose approximately 9” and remained in the visible ‘safety zone’. I might ordinarily calculate this to be 18” of water column which would equate to .65PSI, but because of the difference of the copper ID and sightglass ID, I’m pretty sure this is incorrect. That, plus input from LWTCS and Myles, a boiler should generally run about .5PSI.
Not knowing what actual pressures I would be facing, I bought a pressure gauge. The thought was to hopefully have it read anywhere from .5psi to 3psi. (The 5psi gauges were prohibitively expensive). As it turned out, the needle never moved on either test and proved buying the gauge to be a useless exercise, that is unless something clogs one day and causes the pressure to spike and the gauge to display a timely warning.
At the end of both tests I enjoyed the simplicity of opening up the vacuum valve that I installed between the thumper and boiler. It is a quarter inch stainless ball valve that could be opened safely with an ungloved hand and worked nicely. On the second test, since it was just vinegar and water I couldn’t help entertaining myself and at the boiler’s highest pressure flipped the valve a few times, causing the water in the sightglass to raise and lower on demand.
Conclusion
I feel comfortable with my choice of safety device for my thumper and confident it will handle an overpressure situation safely. I know far too little engineering to design an optimum device, but by interpolating the numbers I do know, I was able to scale a device that satisfies both of my original requirements. What I got out of the process was a chance to learn a few things and upgrade my keg while getting to build something new. And like Yummy says, “Can’t have enough manometer designs.”
Still needed is to insulate both vessels and interconnecting plumbing, design/build a steam injector for thick mashes and modify my stubby quarter keg for thumping, but one thing at a time.
Conclusion
- Deplorable
Copper porn! I'm gonna make a sammich and read this!
- Deplorable
Well done TB. I know you put some work into this write up, and your still porn is always a treat to the eye.
Nice build
What kinda braces have Ya got in mind to protect the glass.
- SaltyStaves
Well done. I'll have to take some inspiration from you when I finally get around to building my thumper.
Fantastic build and writeup TB
Hope it works well for you .
- Dancing4dan
That’s a thing of beauty! Thank you for doing a write up and pics.
Marcus Aurelius
Marcus Aurelius
- Twisted Brick
Thanks for the comments, gentlemen. It's because of you guys I went down this particular rabbit hole.
StillerBoy
Congratulation TB..
Nice work, and a unit to enjoy the fruit of your labor..
Mars
Mars
– Albert Einstein
– Albert Einstein
WithOrWithoutU2
Very nice, sir. Very nice. Looking forward to hearing more on how this goes for you.
- SassyFrass
- Location: Sittin' on the side of the Mountain sippin' and smilin'
Very nice work and a great write up. You should be proud of both. Thank you.
SF
SF
Real good info for New Folks:
- Twisted Brick
Great question, Shady. I have some copper u-brackets that need to be bolted to a cross-piece of either copper or stainless I could use. I have also been on the lookout for a bracket like this one. Most likely, I will just extend a length of stainless rod from the keg skirt to the bottom of the manometer. The whole apparatus is surprisingly stable just by itself altho it vibrates when the thumper is a-thumpin'. The glass is thick enough that it can be banged up against stuff and it just bounces off. Don't ask me how I know! I have two replacement glasses just in case.
- LWTCS
Can you make a protective sleeve with a peice of copper tubing?
Using a grinder to cut a slot down the length of the tube to make a viewing window,,,,if you see my meaning?
Also, that's a nice looking outfit.
- Twisted Brick
That’s a great idea, Larry. I’ll see what I can come up with.
fzbwfk9r
- Location: Smack Dab in the Middle of God's country. Saskatchewan!
What's the difference between this and a pot still with thumper?
I have read of folks running straight water in the pot, and distilling on the grain in the thumper.
Why do you need a pressure gauge on an open system?
Because with a thumper it is not as open as without one.
tiramisu
Just saw this thread for the first time.
That is quite the little monster.
Copper porn and steam injection for grain in.
very nice.
very nice.
fzbwfk9r
but no one worries about a pressure gauge on a Pot/Thumper, and from what I can see, this unit operates the same way.
Steam injection.
I have never seen anyone state a Pot/Thumper is a closed system
As long as there is a permanent vent of some sort, the system is "open". What little pressure there is in a thumper is a non-issue.
I have seen systems with multiple thumpers, each one theoretically creating additional chance for increased pressure.
I'm not flaming here, just trying to understand why so much effort was spent on something that, from what I understand, is not needed.
- LWTCS
Does not at all operate in the same way .fzbwfk9r wrote: ↑Sat Mar 13, 2021 10:14 ambut no one worries about a pressure gauge on a Pot/Thumper, and from what I can see, this unit operates the same way.
Steam injection.
Think about it for,,,,,,,,at least one minute.
- LWTCS
Far more pressure applied if the thumper is charged with a full charge of grain in solids.
Butch27
I'm not so sure about that. I would like to see someone do a test on that one. (I do not have the equipment to do so at this time) I have seen people with a thumper put all manner of things in the thumper to flavour their spirits. Crushed fruit would not be all that different than grain solids. Many here talk of racking off the clear fluid off of a mash and put the rest in the thumper without a PRV of any sort. As soon as people here hear "steam rig" they immediately associate that with danger. The truth is that this can be a dangerous hobby but steam stripping as described in this thread is no more dangerous than a boiler and a thumper.
- LWTCS
So are you saying that a thump keg with a full , all grain charge carries the same pressure as a typical charge then?Butch27 wrote: ↑Sat Mar 13, 2021 11:01 amI'm not so sure about that. I would like to see someone do a test on that one. (I do not have the equipment to do so at this time) I have seen people with a thumper put all manner of things in the thumper to flavour their spirits. Crushed fruit would not be all that different than grain solids. Many here talk of racking off the clear fluid off of a mash and put the rest in the thumper without a PRV of any sort. As soon as people here hear "steam rig" they immediately associate that with danger. The truth is that this can be a dangerous hobby but steam stripping as described in this thread is no more dangerous than a boiler and a thumper.
Notwithstanding that most beer kegs are quite durable, a stick built thumper that is 100% built with copper roof flashing and soldered,,,,is not even the same animal.
You do understand the difference yes?
Butch27
So you are saying that the pressure in the thumper is the problem. Interesting.LWTCS wrote: ↑Sat Mar 13, 2021 11:36 am ...
- LWTCS
I'm not saying it's problem any more than the pressure in the steam generator is a problem. Are you literally saying that you don't understand the pressure difference between a charge that only covers the vapor inlet pipe compare to a fully charged vessel with grains?
I'm saying that a a thumper that is typically used as a thumper, used as a secondary vessel fully loaded with grain in solids deserves more caution.
Do you not see my point or is this merely an excersize in debate skilz?
Butch27
Will there be a difference in boiler pressure? Sure. Will it be a meaningful difference? I doubt it. I am thinking 0.5 to 1.0 psi, so tough to even measure on a gauge. A manometer should work so maybe Twisted or Shady might do the experiment for us or maybe they know from past experience although Twisted is just putting his together. If I am correct and the difference is only a psi and that psi makes a difference to your rig, then you have cut the engineering way too close.LWTCS wrote: ↑Sat Mar 13, 2021 12:34 pm I'm not saying it's problem any more than the pressure in the steam generator is a problem. Are you literally saying that you don't understand the pressure difference between a charge that only covers the vapor inlet pipe compare to a fully charged vessel with grains?
- LWTCS
Butch,,,,,not going to necessarily disagree with you.Butch27 wrote: ↑Sat Mar 13, 2021 2:17 pmWill there be a difference in boiler pressure? Sure. Will it be a meaningful difference? I doubt it. I am thinking 0.5 to 1.0 psi, so tough to even measure on a gauge. A manometer should work so maybe Twisted or Shady might do the experiment for us or maybe they know from past experience although Twisted is just putting his together. If I am correct and the difference is only a psi and that psi makes a difference to your rig, then you have cut the engineering way too close.LWTCS wrote: ↑Sat Mar 13, 2021 12:34 pm I'm not saying it's problem any more than the pressure in the steam generator is a problem. Are you literally saying that you don't understand the pressure difference between a charge that only covers the vapor inlet pipe compare to a fully charged vessel with grains?
However, the difference between 3 lbs and 4 lbs is significant. A child's bicycle tire holds 20 pounds and yet an atmospheric boil can be a serious burn.
Further, I also agree that cutting the engineering short could be a catastrophic problem. That is indeed the point.
Let's word our responses so that newbies understand the consequences.
So often folks will default to the easiest standard. They don't really understand that risk for a qualified mechanic is not the same thing as risk for a straight up green newbie. We have all manner here.
Haven't you been paying attention to all of the god forsaken references to "George" lately? We have all manner of participants here Butch. You are not just talking to skilled participants.
A stick built thumper made from copper roofing flashing is not at all the same animal as a SS beer keg.
That matters.
If you want to debate and make an assertion, be more specific. Be more skillful in your response.
If you fancy yourself as a mechanic then become a better teacher.,,,,as should I.
Butch27
That can happen with either a steam rig or boiler/thumper setup. Many seam to like to do fancy things with the line into the second vessel. Personally I think just a wide open line cut on a slant is the way to go.
That works great when the thumper is full of liquid.
But not as good when it's full of a thick mash.
Instead of just cutting the thumper inlet tube at a slant.
I use a SS mesh tube to help spread the heat around.
I figure it's better to have the steam injected over a large area.
Than it is to blow it all in one spot.
