Cracked Corn
*MoonShine*
Cracked Corn
Post by *MoonShine* »
Is Cracked Corn, chicken feed, hog feed, all the same stuff?
Husker
Re: Cracked Corn
Post by Husker »
*MoonShine*:
I have heard cracked corn called "chick feed" or "chicken scratch". If you look at it, and all you see is cracked corn, and it smells like cracked corn, then I am pretty sure you can use it in the same manner.
As for hog feed, I could not answer. It may be corn, but have a lot of other things in it. If these things are simply nutients, then it will probably be fine. Hogs eat a lot of strange things.
However, if you can get "simple" cracked corn, then you know what you are starting with, and when things get added to it (by you), you will know exactly what is in the mash.
H.
golden pond
Post by golden pond »
Cracked corn is just what it implies, corn kernels thats been cracked into pieces., nothing else added. It's best when it's 6-7 pieces per kernel. Chicken scratch feed is a much finer cracked corn and will contain powdered corn, it will work but will be harder to seperate the beer from it.The hog feed is powdered corn with other ingredients added and I would not use it for a mash. Cracked corn is no problem to find or buy or you can crack your own in a kitchen blender if need be.
Never follow good whiskey with water, unless you're out of good whiskey!!!
hornedrhodent
Re: Cracked Corn
Post by hornedrhodent »
What about popcorn - the sugar coating should be an advantage.
welska
Cracked corn
Post by welska »
We use cracked corn and re-grind it....since it has been broken once there are no stones and it's relatively clean.
Use a liquifaction enzyme to break it down and saccarify with a different enzyme.
Brian
Fourway
Re: Cracked corn
Post by Fourway »
that would be a great approach if you were looking to make vodka from corn, it's a surefire way to make lackluster whiskey though.
"a woman who drives you to drink is hard to find, most of them will make you drive yourself."
anon--
