Easy Flange 2.0
Easy Flange 2.0
Tried making my first "Easy Flange", it didnt turn out as well as I had hoped. So i did a lil experimenting. This is what I came up with:
Use #4 (vs #6) bare copper wire.
1) Wrap wire around pipe prior to hammering the wire.
2) Tapped the outside edge of ring to 30-40 degree angle
3) Solder on and be done
With this method, you dont have to "build" up the flange with solder.
It takes less than 10mins before its time to solder on.
Two of them can be joined together w/ a tri clamp
Oh, and credit goes to RumBull for the Original Easy Flange
Re: Easy Flange 2.0
Pic of it attached to a keg
Re: Easy Flange 2.0
Don't think so, there is a sticky under my posting of an easy flange.butt wheat wrote:Oh, and credit goes to RumBull for the Original Easy Flange
OD
Re: Easy Flange 2.0
Sorry bout that olddog..When I click on the Easy Flange Sticky, it comes up as Rum Bull???
Re: Easy Flange 2.0
Nope, in the main menu, under related hardware, third stickydown, "Easy flange" poster olddog.
Re: Easy Flange 2.0
Olddog,
You are correct. It just cnfused me that when I click your post, the very first post is by Rum Bull demonstrating with pics how to do the flange...
Re: Easy Flange 2.0
The original post could have been edited, with other alternatives.
BTW your idea is good and worthy of a mention.
OD
OD
Re: Easy Flange 2.0
Ahhh, ok, i see what you mean. Well, again sorry for giving the wrong person credit.
Re: Easy Flange 2.0
Nice work butt wheat! The easy flange has come a long way. I was wondering what you had used as a gasket at the boiler connection and also at the flange to flange joint? Its been some time sense your post, has there been any draw backs?
+1 for olddog for the original easy flange. Heh, the olddog came up with a new trick, what's next.
Re: Easy Flange 2.0
Been looking for a flange this easy for my new build.
Sent from my HTC One X using Tapatalk 2
