Yeast Volume per Pound
I am wanting to purchase some Superstart Distillers Yeast. I'm not sure how much to order. I would like to know approximately how many ounces/cups/etc (by volume) are in one pound of this yeast. Thanks.
FlyboyTR
Lower Alabama
Lower Alabama
Re: Yeast Volume per Pound
454 grams in pound,, most packs you buy are 5 grams ,so that's about 90 packs.
Dnder,
Thanks for the reply...however, I'm still at a loss as to the approximate volume of a pound of this yeast. The recipe calls for 1/4 cup. So I need to have some idea how many 1/4 cups are in 1 pound of the yeast. Thanks
FlyboyTR
Lower Alabama
Lower Alabama
Does it really matter, if the recipe calls for a quarter cup then pitch a quarter cup. How many quarter cups to the pound is really just theory.
a cup is 8 oz ,,1/4 =2oz ,a lb is 16,,so you git about 8 washes out of a LB. (there is a slight difference in a liquid cup and a dry cup)
(6 grade hillbilly math agin)
I use super start a lb of it will over fill a pint jar with some left in bag.Bag it comes in says add 1-2 lb per 1000 gallon mash.I like it does well in hot weather with out causing off tastes . Ive used it for fruits and grain mashes with good results and I don't think ya can beat it for rum. However in cold weather I go with ec1118. or a mix of the two.
Dosn't the dominant yeast take over.tater wrote: However in cold weather I go with ec1118. or a mix of the two.
[quote="tater"]I use super start a lb of it will over fill a pint jar with some left in bag.Bag it comes in says add 1-2 lb per 1000 gallon mash.quote]
Thanks Tater,
Having an idea of the actual "volume" of a one pound (16oz by weight) bag is the answer I was looking for. (I occasionally deal with chemicals where one pound could fill up a gallon jug and a different chemical would only fill up a coffee cup) Also glad to know it does good in warm weather...since things are starting to heat up in L.A. Thanks again!
Thanks Tater,
FlyboyTR
Lower Alabama
Lower Alabama
Ive heard that also all I can say is it does well for me. If one eatin the other what making it work then so be it.olddog wrote:Dosn't the dominant yeast take over.tater wrote: However in cold weather I go with ec1118. or a mix of the two.
olddog wrote:Does it really matter, if the recipe calls for a quarter cup then pitch a quarter cup. How many quarter cups to the pound is really just theory.
+ 11111111
blanik
Cumudgeon and loving it.
"A pints a pound the world around" what the old timers say.... ok, thats what I say... I guess nowadays I am an old timer...
