Thumper question
clones2
Thumper question
Post by clones2 »
In process of building my first pot still and I have a question about the thumper.
First - for something around a 5 gallon pot - how big should the thumper be?
Second - This is what I dont 100% understand about the thumper. If it starts 50% of water... the initial incoming vapor condenses to create more liquid... Is there a chance that the thumper would ever fill up and overflow with liquid before the vapor starts flowing out of it into the condenser???
Yes I am a bit of a newb at this. :-)
Thanks.
Bull Rider
Re: Thumper question
Post by Bull Rider »
Welcome Clones2:
I see this is your first post, what I'd suggest is that you get your pot still up and running. Learn it well, run it without a thumper until you're producing a product that's pleasing to you. Pot stills are pretty basic, but that's not to say that there isn't a considerable learning curve.
When you've achieved that level of skill, then move up to a thumper. You may like it, or you may prefer just the pot still. I've run a pot still dozens and dozens of times, and I've considered building a thumper. I have all of the components, but I'm content (for now) to run my current setup.
Bull.
thumpers are often 1/2 to 1/3 the size of the primary boiler.
Yes there is a chance that that flooding can be an issue.
Typical thumper run only needs liquid enough to cover the inlet.
Upward turn lyne arm with a jacketed condenser can give you the self fill capability. Means more ABV.
Elevated thumper with return drain to the primary can illiminate the flooding issues.
Reflux condenser atop that,,, and you got yourself a tuneable thumper...
clones2
Post by clones2 »
Thanks for the advice.
staggerlee
Post by staggerlee »
Personally, I run a 16 gal. boiler with an 8 gal. thumper. I fill the thumper to just above the inlet and on average end up with the thumper being half full after 10-12 hour runs.
staggerlee wrote:I run a 16 gal. boiler with an 8 gal. thumper. I fill the thumper to just above the inlet and on average end up with the thumper being half full after 10-12 hour runs.
Kinda heat you run?
I'd shoot my self with a 10 or 12 hour run
Barney Fife
Post by Barney Fife »
Yeah, but he's talking about a 16 gallon still, LW. That said, I'd go nuts, too! Can't keep myself focused on anything for that long... ;)
staggerlee
Typically, about a 13-14 gal charge with propane. Slow enough just to get a pencil lead stream. It can definitely feel like an eternity at times.
Pencil lead sounds good.
Didn't mean to come across like an A-hole.
I do apologize.
I'm not typically charging with much more than 7-8 gallons..recon thats the difference.
staggerlee
Hey man no worries, I didn't think you came across like an a-hole at all :lol:
