Stopping in middle of run?
I was wondering if you can stop in the middle of a run and then fire it back up, say, next day without any problems. If so is it as easy as just turning off your heat and walking away and then firing it back up ?
Re: Stopping in middle of run?
No problem.
Reflux column:
1. Turn off heat.
2. Wait till temp drops below 60*C at the top of the column.
3. Turn off coolant.
Re-starting the next day is the same as your first start, except the further into the run you are the shorter the stabilization period required.
Pot still:
1. Turn off heat.
2. Wait till the drips stop.
Reflux column:
1. Turn off heat.
Pot still:
1. Turn off heat.
And YES you do make your cuts again
