Brandon O's Graff Cider
For all non-scientific beerology purposes, this is a cider. (I know, I know....but its got hops in it!)
Jay Huff and his apple bee got me started on some experiments and this is what I have come up with.
I noticed Ed's Apfelwein tasted super hoochy until it was about a year old. When it's about a year old tho it does taste like a good cider, but doesn't have the body a good cider does.
So, how can I make something that will taste good faster and also have body?
1. Get rid of the wine yeast and use a clean fermenting beer yeast
2. Get rid of that cheap sugar and use some light DME
3. Balance the tart flavor of young cider by using specialty grains.
4. Later on, I found hops also helped balance the overall flavor. BUT ONLY A TINY BIT, DO NOT USE MORE THAN CALLED FOR
If you like a clean, malty, not too tart easy drinking cider style beverage then this is your drink.
Materials needed for a 5 Gallon Batch
Clean fermenting yeast I have used Nottinham and Safale-05, both are good
.5 lbs of Crystal 60L If you use cheap store brand juice, I reccomend 120L. Cheap juice tends to turn out a tad tart and this will balance it.
1 oz of torrified wheat ( head retention, I've never used more than 2oz)
4 Gallons of apple juice.
1 gallon of water
2 lbs of DME ( I use 1 lb. amber and 1 lb. light DME)
0.5 oz of you favorite hops ( right around 6% AA, I have used 18.5% AA summit hops before and it took a month after kegging for strong bitterness to blend nicely)
WARNING! IF YOU ARE GOING TO CHANGE THE AMOUNT OF HOPS USED, MAKE IT LESS NOT MORE, it's really just too bitter with any more.
Directions for brewing
Steep the 60L and torrified wheat in .75 gallons of water @ 155 degrees for 30 mins.
Sparge with .25 gallons 170 degree water and throw away grains.
Add DME and bring to a boil.
Add hops when boiling starts and boil for 30 mins.
Cool down the wort (if you choose not to cool the wort and just let the AJ do the cooling then your cider won't be as clear). I don't care about clarity so I just let the AJ do the cooling, but if you stick your pot in the freezer and let this get down to 70 degrees or so your cider will clear fairly easy. Pour the wort and apple juice into your carboy and pitch yeast.
Ferment 2 weeks at 64-68 degrees then keg or bottle.
I keg, and this stuff is VERY drinkable as soon as it is carbonated.
SUPERB taste and drinkability after 2-3 weeks of aging.
People bottling, it will have SUPERB taste and drinkability after the standard 3 week bottling period for carbonating.
Last edited by Brandon O; 06-10-2009 at 07:42 PM. Reason: Cooling the wort before adding to the AJ really helps clarity.
Just figured I'd throw this one in here, it seems to have quite a following elsewhere. I'm going to make a batch this weekend. I have a jug of Ed's Apfelwein going right now and I'm not entirely satisfied with it. It's drinkable, but I'm going to try this one.
1 gallon of water
Not typically one to floss
Re: Brandon O's Graff Cider
Update
I'm making my first batch today, but I messed around with the recipe. My local brewshop didn't know nothin about nothin about the torreated wheat or whatever that was, and I didn't put any malt in. Also, I put in four times the amount of hops Homey used 'cause I like it bitter. And threw in another four pounds of brown sugar, and 3 pounds of medium DME which boiled over while my wife was stirring.
I figure she let it boil over to make up for me taking a picture of her after the baby puked on top of her head instead of helping her clean up.
We'll see how she goes.
Another update:
The malt smell disappeared within a week, it smells more like apfelwein now. The hops smell is gone, too. Still bubbling happily away, doing its thing. Supposedly at three weeks it starts to taste/smell amazing, this is only about a week in.
It's two weeks in now, still smells good, bubbling happily away. I'm going to rack into a secondary tomorrow and start a new batch in the primary. ETA: I stopped by the brewshop today and picked up some bungs and airlocks, so I finally airlocked the graff. It's still bubbling HARD. It probably lets a burp loose every 3-5 seconds, two weeks in. I think this one's gonna be stiff.
One more update:
This is MUCH better than Apfelwein was three weeks in. It's not hoochy, it's not thin. It's got a full flavor to it, but it needs a LOT more hops than the recipe called for. I have the materials together for another batch, and I'm going to use four times the hops in the recipe to try to get a little bitterness to it. Also, skipping the light DME and going with amber. I might even spring for bottles and carbonate it instead of leaving it still in mason jars.
I've got about 25 quarts of it put up, so I'll drink some now and save some for later.
I'm about 80% done with the first batch. This was pretty good, and I will make more. I'm going to use about five times as much hops though, I like my beer bitter. I added some brown sugar and whatnot with this recipe to kick up the ABV and I guess it did a good job. I put a jar in the freezer last night and forgot all about it. Checked today and the graff is completely not frozen at all. Not even a skim of ice on it 16 hours later.
Nobody else is commenting on this recipe so this is my last bump on the subject. I remain happy with my results.
Personally I don't drink beer at all hence no comment.pistachio_nut wrote:I'm about 80% done with the first batch. This was pretty good, and I will make more. I'm going to use about five times as much hops though, I like my beer bitter. I added some brown sugar and whatnot with this recipe to kick up the ABV and I guess it did a good job. I put a jar in the freezer last night and forgot all about it. Checked today and the graff is completely not frozen at all. Not even a skim of ice on it 16 hours later.
But if you are happy with the brew, that's great.
And it is certainly relevant to distilling (grain washes) but I have not tried them yet, just fruit brandies and sugar washes. No spectacular results but I am working on it.
Happy Christmas.
I stopped by the brewshop today and picked up the hops and yeast to make another 10 gallons. Looks like I'm going to have to chug through a little more Ernest & Julio to put some more jugs up.
ressurecting this good recipe.... i suggest some of you give it a go...
Sounds like a good summer-y drink... might have to try this
I put another 2 batches of this down today... One with nottingham and one with safale 05.... Used cascade hops.... I'll report back in a month or so on which one is better.
I've probably brewed 100 gallons of Graff by now.
Funny thing is, it's not really my thing. but my wife and all of my friends love it, so i keep a keg on tap all the time.
Thanks for all the info! We made our first test batch with 1.5 gallons of pale ale using a partial mash with 2 lbs of DME, 2 lbs of grain, 1oz tettnang hops, 4 gallons of motts apple juice, and 05 yeast. Got about 1.65 OG and down to 1.01 in a week. Planning to transfer to secondary for a week and keg. Wondering if I should add some hops for a little more bitter. The tettnang are fairly mild and I want at least some of the beer characteristics to show through. Happy brewing!
Brewed 2.5 gallons of this tonight. Replaced 1 qt of pressed cider with bottled black cherry juice. Us-05 yeast and calypso hops. See what 2 weeks will bring.
Anyone still making this?
I'm gonna invest in stocks and bonds. Lace stockings and "un"Bonded Whiskey.
pistachio_nut what was your og and what yeast were you going with? most of my beers ferment out with in the week.
sounds like this has been given the tried and true stamp so might have to give it a bash.
It's tasty however I used a hop with high acid
Sent from my QMV7A using Tapatalk
ksarrow wrote:It's tasty however I used a hop that left it a bit too bitter for my taste. I bottle carbed and pasteurized with success.
ksarrow wrote:It's tasty however I used a hop with high acid
