Wood fired steam boiler?
Living off grid. Or at least trying to. Presents a few problems along the way. One being the lack of any amount of access electricity to use for hobbies like this one.
My idea. Build a wood fired steam boiler for direct steam injection. The steam will be used for cooking and mashing grains. Distilling alcohol and essential oils.
The equipment. I will be using an old style stainless keg for the boiler. It has a sankey valve on top. I will come off it with a 2" triclamp T. The side port will be plumbed to the still boiler/mash tun. The other port coming out the top will have a valve and a large jacketed or shotgun condenser. Basically when the valve is closed all steam goes to the still boiler/mash tun. With it open the steam will be recondensed and drop back into the boiler. There would be no restrictions and the steam path would never be blocked. With the valve open. It would be open to atmosphere through the condenser with it closed it would have a path through the still boiler/mash tun.
For the heat I plan to use a simi brake drum. Flipped big side down. With the axle hole pointing up. Make a door on the side to feed the fire. And a damper to control the flame. We started doing this for Dutch oven cooking. The drum being cast iron holds heat really well. The axle hole makes a good burner area. Tack a few little plates on it for stand offs. And sit the steam boiler keg on top.
I might possibly weld two droms together and make like a pot belly stove? But that may end up being to tall. I will have to play with it and see.
I have the keg 6 of the drums and some of the bits and bobs to build it. I don't have any pics at this time. I will try and get some with the stuff mocked up. So you can get a better understanding of my thoughts. It will help me also.
The only thing I have to work out is the condenser. How I will supply it with water. Without electricity. I may have to go a different route with it. Maybe feed that side into another tank full of cold or cool water. I don't want it to be too overly complicated. If I have to I will just bent the access steam into a safe place. Like an open air protected box or something. I would be wasting water if I did this though. That's another thing we have a shortage of. Good water. Well it's available. Just not easy to get and use to just waste. I have access to no less then 20 springs and a good well. But I have to haul that water to the homestead. And I only have approx 500 gal of storage space at the homestead.
Thoughts ideas are welcome and or wanted?????
Re: Wood fired steam boiler?
Here is a pic of us cooking with a Dutch oven on one. So you can get an idea of what I'm talking about.
- Attachments
- image.jpg (23.07 KiB) Viewed 8018 times
A lot of interesting thoughts. I've often thought of how the old timers would regulate heat with wood. An art really. Could you put a tank on a stand and use gravity? Reason for a flake stand. Do you have wind for a windmill? Best to you.
I like where you are going with this, keep the pictures coming please
Electric pump with solar panel and battery?
Only thing I can think of that requires no energy source would be gravity, 45 gal drum up high, drain into a pail and refillPrairiepiss wrote:The only thing I have to work out is the condenser. How I will supply it with water. Without electricity.
There appears to be an inverse relationship between tangible distilling problems and possible drinking problems...
Sounds awesome. I'm actually quite jelous.
Now on to your problem.
I see two options.
One. Flake stand. 55 gallon drum or bigger should suffice.
Option two. Air cooled. There has been a lot.of advancements into the practical side of it.
Not sure where you are or what you have access to, but there are many ways to skin the cat.
Def keep the updates coming as long as you are able to.
Yak
I see two options.
Yak
- T-Pee
I was thinking the same thing, Yak.yakattack wrote:Option two. Air cooled. There has been a lot.of advancements into the practical side of it.
tp
Handy Links:
The Rules We Live By
GA Flatwoods sez
Handy Links:
GA Flatwoods sez
- Kegg_jam
Big ole worm in a barrel seems easy enough. Wouldn't ya need electric for cooling fans on an air cooled condenser?
It would have to be a really big air cooler.
I think I would just vent it if I have to build something too big. I could do maybe something in the 55 gal drum size. But we will see. I can get a small water circulation pump. That uses very little energy.
But then again I have to also cool my still condensers anyway. So that will all add up to more then I will want to run. I will have the reflux condenser and shotgun product condenser to cool. I could change out and go with a worm and flakestand for a product condenser. But the reflux condenser will be the big challenge.
Plan B
Move the still to the water
Plan C
Use a small water cooled motor to drive the pump
And the hot water from the engine could be used as a 15psi boiler
- Kegg_jam
Plan D
Generator that runs off bio-fuel
Any plans for a rod pump windmill? Used to have them all over the Midwest for cattle tanks. Around 5k installed can get you 150' lift at 100 gph (or more) when the wind is blowing. Good for dishes, showers and condensers.
Low tech and will last longer than either of us.
heartcut
W. H. Auden
W. H. Auden
Ok did I say the budget is almost nonexistent?
If I had the budget. I would just double up my solar system and run Electric.
I haven't done ANY research on steam ,but could and inline steam engine or turbine be fabricated to provide direct drive or produce electricity to power a circulation pump?
Hydraulic ram pump for water If you have a source of water that has enough height. No power needed, regulate flow with a diverter so what you aren't using flows back or other needed areas.
I've read heating with wood is best done with two fires. You take coals from one fire and add to heat the boiler, or remove coals to reduce heat
Haven't seen Goose Eye here of late. I bet he would have something worth saying here about them ole boys.
Subscribed. I've been thinking on how to regulate the heat with a fire. Almost have to have a damper and sealed up stove.
I think it may have been one of goose's posts I read about how to heat with wood. Could be wrong though.bearriver wrote:Haven't seen Goose Eye here of late. I bet he would have something worth saying here about them ole boys.
Edit: great thread here on heating with wood: http://w.homedistiller.org/forum/viewto ... 15&t=13499" onclick="window.open(this.href);return false;" rel="nofollow
Second edit: I think TB has some experience cookin on wood. Maybe he can pop in here.
The two fires idea is something we do when we cook whole hogs on the pit. Build a fire outside and shovel the coals in to regulate heat.
Rich Grain Distilling Co., DSP-MS-20003
http://www.richdistilling.com" onclick="window.open(this.href);return false;" rel="nofollow
https://www.facebook.com/richgraindistillingco/" onclick="window.open(this.href);return false;" rel="nofollow
- Kegg_jam
Sounds like a good episode for survivor man.
Gravity fed from an elevated rain barrel. Maybe hand pump it back up as you go.
You get a workout and get to make likker.
With cooking, you are really just holding the cooking pot at a certain temperature. The BTU's to RAISE the foods temperature is really not that many.
With distilling, we need a LOT of btus on a continuous basis.
Coals give off a little bit of btus at a very high temperature. I think we need LOTS of BTUs at a reasonably high temperature.
I think moving coals won't work that well for distilling.
This morning I'm thinking I'm going to have a stove with gravity feed water, and use it to make steam with a copper coil (no solder). Then I'm going to run that steam into a heat exchanger inside my boiler.
I'm going to limit the energy of the system by limiting the amount of water which goes into the boil inside the stove.
- raketemensch
All of the air-cooled research that I've seen and been involved in uses fans.
A bank of CPU fans running at 12v might not be an issue, I don't know what sort of capacity our "number one" friend has.
I don't suppose there's a brook available?
- BoisBlancBoy
I love the whole idea and am going to be interested to see how you work this. I've got to say I like how you have implemented the truck brake drum!
Good to see you around PP! And what a great thread too!
Instead of a second condenser just route the waste steam pipe directly to your product condenser. Open the valve -steam straight to the PC, close the valve -steam forced through the cook pot or boiler.
A decent sized flake stand and worm seem like the right tool in this scenario. A hand pump can be used to add cool water when/if needed. You can add a hose to the side of the flake stand a few inches from the top to collect the hot water. This could then be manually added to the steam boiler if needed.
- T-Pee
I haven't seen a wood stove mentioned. Damper and regulation come stock.
tp
tp
Handy Links:
GA Flatwoods sez
Handy Links:
GA Flatwoods sez
There are two wood fired boilers on craigslist in my area. Modifying one for a steam generator would be excellent.
It might be worth looking whats in your area.
I've seen wood fire under a steam boiler work.
Best was a long pit under the boiler where you could push wood/fire from one end to the other. Bad news is it becomes the job of a person for the entire distillation to watch the fire.
DSP-AR-20005
DSP-AR-20005
Maybe a little time consuming to build but a bio mass gassifier could get you to where you want. You could use the gas like you would propane or run the gas to an old generator and use electric elements and a pump. Hell you could even use it to charge your batteries and run your house during long periods of cloudy days or storms. Gassifiers aren't hard to build and you can run them with almost anything. If I am remembering right you said you had several huge piles of sawdust on your property, that's a whole lotta electricity just sitting there. Animal dung, grass clippings, pond scum, moss mats, used grain, dang near everything can be used in a gassifier. Anyway just a thought.
Ok here is one of the drums. With both the legs I have available to build it out of.
And here is two drums stacked like a pot belly stove. With One of the kegs.
