Hillbilly Popstar
Post by Hillbilly Popstar »
Titebond III is a food safe wood glue.
"Making likker with a hydrometer and thermometer is like measuring the length of a 2x4 with a clock"
MichiganCornhusker
Post by MichiganCornhusker »
I don't think you will have trouble with the head staying in, but for added insurance, you could melt some beeswax and pour it into the joint where the wood meets the stainless. If you roll the "barrel" while you do it, it would make a nice little seal, like caulk, all around.
Really like this idea, ordering up some inserts today!
Badmotivator
Post by Badmotivator »
MichiganCornhusker wrote:I don't think you will have trouble with the head staying in, but for added insurance, you could melt some beeswax and pour it into the joint where the wood meets the stainless. If you roll the "barrel" while you do it, it would make a nice little seal, like caulk, all around.
Nice! That 's a great trick to have ready to go if you notice a little leak! Ordering some beeswax right now. :)
By the way, the stainless steel tap seals just fine without using the included silicone gaskets, washers, and nut, just by the swelling of the oak. I am editing a post above to include that info.
Hillbilly Popstar
Or you could always just wrap a little Teflon tape around the outside and jam it in tite.
Hillbilly Popstar
Wrap it and jam it...
That's what she said! Ha!
Badmotivator
Leak repair: ImageImageImage
The "leak" had actually already stopped itself weeks ago with dried sugars or whatever. I wasn't going to do anything about it until beeswax came up. :)
bearriver
Post by bearriver »
These are outstanding. Hopefully I will get to try this someday.
Wonderful craftsmanship and ingenuity Badmotivator! :clap:
Badmotivator
Gluing the dowels:
Okay, a tiny amount of wood glue is probably fine but we can do better. Caramel was one suggestion, flour paste was another. I tested both.
Flour paste
Caramel
Results:
Flour paste, like a medium-thin papier-mache paste, works perfectly. After two hours or less I could not separate the test pieces by hand.
Caramel is a goddamned mess and I hate it. I burned myself, of course, and it hardened so fast I couldn't get the test pieces together.
Flour paste it is! I will edit the instructions to take this new information into account.
kiwi Bruce
Post by kiwi Bruce »
If you think the head popping off or even coming slightly loose could be a problem, you could try something like this. The Bain-Marie insert has a raised lip and you could easily make a flat stock piece with two hooks to go over the edge of the insert, then wedge tapered oak pieces against the head and the flat stock. The flat stock will have some spring and guarantee the head will stay in place and stay tight.
P.S. I think you have come up with something quite brilliant with this idea here Badmo! Very very ingenious! Kiwi
Getting hung up all day on smiles
kiwi Bruce
Suitable organic glue....I'd try simple egg white before I'd try some of the other more outrageous possibilities, like...Rabbit skin glue (a traditional furniture glue in the nineteenth century, and still available) or Isinglass (sturgeon, float bladder) You have me hooked on this idea and I'm going to give it a go. Kiwi
P.S. Checking out webstaurant.com Their 6qt is only $8.29 right now, I email them about the shipping.
Badmotivator
kiwi Bruce wrote:You have me hooked on this idea and I'm going to give it a go. Kiwi
Hell yeah, KB! Post some pics if you get one made. Thanks also for the kind words. I'm pretty excited too! I am going to be using lots and lots of these, for one thing. But more significantly, it feels good to make a significant contribution to the home distiller's toolbox.
I really have no concerns about the heads popping off. It came up in the context of heating the barrel to simulate a warm climate. I'm going to test a BBOB half-full of water, heated up to 150F or so, just to put that to rest.
cob
Post by cob »
BMV great work. great idea. the poor mans cooperage.
food for thought, with your off cuts you can make your own dowels, also a spout.
I didn't see any leakage at your joints but a tight tongue and groove joint could be insurance,
made with a router, table saw, Stanley #45 wood plane.
if you put your batten on the outside with stainless screws it could stay as a plaque holder.
stainless screws through the bain-marie could facilitate repairs (maybe).
a torch on the stainless (gently) will flow the bees wax.
remember prior to 150 years ago most everything was done by hand.
der wo
Post by der wo »
kiwi Bruce wrote:If you think the head popping off or even coming slightly loose could be a problem, you could try something like this. The Bain-Marie insert has a raised lip and you could easily make a flat stock piece with two hooks to go over the edge of the insert, then wedge tapered oak pieces against the head and the flat stock. The flat stock will have some spring and guarantee the head will stay in place and stay tight.
I fear, that with the years this would bend/deform the Bain-Marie. But I am sure, something in this direction would be my way, that I can sleep well at night. Something similar, but not clamped to the raised lips but perhaps the bottom. A chain all around the pot, pressing a woodblock in the middle of the wood lid and two turnbuckles to control the pressure.
cuginosgrizzo
Post by cuginosgrizzo »
kiwi Bruce wrote:P.S. Checking out webstaurant.com Their 6qt is only $8.29 right now, I email them about the shipping.
Lucky you. Here you can get 6 liter inserts for no less that 100€ + shipping!
Badmotivator
I got two more BBOBs done today. Both are 4 qt cans. Lightly seasoned, toasted, and charred white oak heads. SS taps. White oak plugs. They are soaking now. :)ImageImage
kiwi Bruce
Just superb, AND great pic's. Kiwi
Hillbilly Popstar
Ok, those last set of pics make me really want to build some! It's a shame they need to be put a away for a year or more. They are really quite beautiful.
Badmotivator
Hillbilly Popstar wrote:Ok, those last set of pics make me really want to build some! It's a shame they need to be put a away for a year or more. They are really quite beautiful.
You can leave them out on the counter, Pop. :)
It's worth pointing out that when you drain these, they can be used again as an ex- barrel. For example, age bourbon in one, bottle the bourbon after a couple of years, then refill it with scotch (ex-bourbon barrel) and leave it for a bunch more years. Also, when it's time to retire the wood, the expense for replacing the wood is going to be like $4 and some shop time. Not bad.
Just think, if you put one or two of these up every month, down the road you've got a serious, no compromises treat coming your way.
Badmotivator
After 1 day of soaking, the BBOB on the left is still leaking, but the one on the right is pretty well sealed. Image
Back upright and refilled with water for another day of soaking. Image
Gezz they look bloody beauty Badmo . :D
I hope they seal soon .
What volume are they in liters ...not real good with all this Quarts stuff :oops:
Been keeping my eye out this week for these Bain-Marie things , so far haven't found anything . Might have to visit a kitchen shop . Theres got to be something SS in those shops :thumbup:
Yummyrum wrote:...keeping my eye out this week for these Bain-Marie things , so far haven't found anything...
Here's one: https://www.katom.com/175-78820.html" onclick="window.open(this.href);return false;" rel="nofollow
Badmotivator
Leak test on those latest two BBOBs shows improvement over yesterday, but neither one is completely tight yet.
I am working on some ideas about how best to toast the oak. My goal (I think) is a deep toast that penetrates about halfway through the wood, and no toast at all on the outside half of the wood. My hunch is that untoasted wood swells better than toasted wood does. Testing that now.
The wood I have toasted so far was done in an oven over a couple of hours at about 425°F. That'll free up some vanillin! But no barrel-maker does this, of course.
kiwi Bruce
I was using the staves from a bourbon barrel to age my scotch and made the mistake of using the staves from the head. The head staves are not toasted as heavily as the body staves for fear of them leaking. I came very close to not being able to use the whisky it was so tannic. So... be careful with the char on the head. Kiwi
Badmotivator
kiwi Bruce wrote:I was using the staves from a bourbon barrel to age my scotch and made the mistake of using the staves from the head. The head staves are not toasted as heavily as the body staves for fear of them leaking. I came very close to not being able to use the whisky it was so tannic. So... be careful with the char on the head. Kiwi
Interesting. So toasting reduces tannins? Does that lend support to the idea that a deep toast is probably desirable?
kiwi Bruce
Yes, it has to be. We have someone on HD who was a copper, I'll look up his handle and post it here. He would definitely know.
der wo
Post by der wo »
The most bourbon barrel wood is only toasted while the bending process. If you look at JD-smoking wood, it doesn't look toasted at all. But there are some brands, which point out, that their barrels are extra toasted before the charring in contrast to the most other bourbon barrels. Woodford for example.
All my trials with sticks taste more like deep toast. I will try next time no or almost no toast to get the other flavors.
Edit: More about sticks, but anyway a very good article:
http://homedistiller.org/forum/viewtopic.php?t=6597
ShineonCrazyDiamond
Post by ShineonCrazyDiamond »
kiwi Bruce wrote:Yes, it has to be. We have someone on HD who was a copper, I look up his handle and post it here. He would definitely know.
Scout
Shine on you crazy diamond."
kiwi Bruce
Thank you SCD your right it's Scott.
gr8brewer
Post by gr8brewer »
Seriously I'm always impressed by the ingenuity and collaboration that goes on here.
I think even wine maker's would be interested in these.
Badmotivator
Always learning!
Well, the latest two BBOBs failed to seal. One was weepy, the other was drippy. I tried sealing the outside edge with beeswax but it was not a complete fix.
My best guess right now is that I over – toasted the wood, leaving it less able to swell. I had those wood blocks in the oven for like 2 or 3 hours at 425F. Way too much.
I did a small 2-day-soak test with some blocks of oak, and indeed, the untoasted wood gained about 2% width whereas the thoroughly-toasted offcut from these BBOBs didn't change dimension at all.
More tests and refinements to follow. :)
