SO after about a year reading and the christening of a new addition to the family...Pepper
...I felt a sugar wash just wasn't enough... It's time
I started with Jimbo's Easy 1/2 Barrel Bourbon and Gumballhead recipe with a minor modification...rye instead of wheat (also citric acid instead of backset or lactic acid...). With some help from the man himself along with a few others looking over my math it all looked good.
The Builds: A little shout out to all that helped with the wiring and other suggestions here... http://homedistiller.org/forum/viewtopi ... 85&t=61846
Finally...a wort chiller but since I didn't get to use it...no picture.
The Contents
22 lb of cracked corn - smashed in aforementioned mill
6 lb of 2 row malt
3 lb rye malt
12 gallons H20 brought to a near boil with the gypsum and 15 ml of citric acid (1 tablespoon)
SEBstar HTL and SEBamyl GL at the appropriate time/temps/pH
The Process
Boil 12 gallon H2O with the gypsum and Citric acid as per Jimbo's recipe
Add the 22lb corn to bring it down to temp aroung 180F
Add the SEBstar HTL and stir frequently (about 7 ml)
Wrap it up and wait overnight (about 8 hours in all)
In the am - temps at 140 F - Add 2 row and rye
Stir frequently and add SEBamyl GL (about 7ml again)
Cover and set for 2 hours.
Check conversion
Cool to pitch temp
Pitch
Wait
The Screw Ups
12 gallons of water 10 gallon BOP...
Under judged the MOP (Medium Ole Pot) with its included grain used to assist the undersized BOP
Temps after corn only 170's F
AM temps in 130'sF
The Results
Full starch conversion (?)
OG: 1.056
Volume approx 10 gallons
Tips
Get a cheap tarp.... do all of this over said tarp
Wringing 31 lb of grain is a pain in the arse. It's doable but have a better plan than hand wringing.
Have appropriate size pot - "Can I Mash It" about 1/2 way down this page... http://www.rackers.org/calcs.shtml" onclick="window.open(this.href);return false;" rel="nofollow
Plans
If this sip turns out as good as everybody says it will... will need a bigger pot (Keggle)
Large BIAB that's reinforced and most likely a pulley system ( there is a cheap winch on sale at HF right now..... Hmmmmmm.... )
Some kind of wringing system...mop bucket, etc...
Questions
The mash in the cup...I don't see any black/blue - is this fully converted?
Does the final mash look OK? It just seems cloudy. After the pic it actually settled quite nicely leaving a clear area on top and it tastes quite sweet... but asking all the same.
Many thanks to all that gave assistance on other threads... Every time I get into something new I get the chance to realize what a great place this is...
