With a Bok it is worthwhile.frunobulax wrote:I think I do it out of habit from running my Boka.
Running a column still
Re: Running a column still
- Rain Distillate
I always pull the fores then put it into reflux.TedL wrote:OK cool, as you probably read in my earlier post I was refluxing for 30-45 minutes and taking fores and heads off after that. But I'll try and reflux for 20 minutes or so, that'll save me a lot of propane.frunobulax wrote:I wait 15-20 mins then pull the Fore's and heads off slow, then slowly increase the take off rate when I feel the heads are almost gone. It's hard to say how long
it takes, every run is different. 30-45 minutes I'd guess
- Rain Distillate
2-3"TedL wrote:What size columns are you guys running on?
4" 4-5 Perf plates and have a 24" packed section for vodkas/neutrals
It is what you make it
4 plates in 4 inch column
This thread has been helpful. It's nice getting feedback from other column/flute users. I've been on the still dragon forum and I think they just like running their still just for something to look at, not to make anything that's good to drink.
Never argue with a fool, onlookers may not be able to tell the difference.
Frunobulax, your entire still is copper? Even your boiler? I would love to see some pictures of your rig.frunobulax wrote:I have a 4" column. The sections look just like Tedl's but the entire still is copper.
- frunobulax
No, Not the boiler. Just plate sections, Deflag. Crossover, shotgun and parrot. I do have the same 3" Stainless windows though.
Mine Is all copper I built myself. [img]https://uploads.tapatalk-cdn.com/201702 ... 71f244.jpg[/img]
Master Distiller
Master Distiller
- der wo
Wow. Looks like this?
[ing]https://uploads.tapatalk-cdn.com/201712 ... rf5136.jpg[/img]
Sent from my wrksf using Dmlkn
Please don't use tapatalk for posting pictures. Use the hd attachment function. And disable the "Sent from..."
- frunobulax
You should post the picture here. Anyway, I went to your link. Awesome job on that boiler.
Is there a deflag on there?
not on that run but do have one that u use for straight neutralsfrunobulax wrote:You should post the picture here. Anyway, I went to your link. Awesome job on that boiler.
Master Distiller
Tinner22, please read and heed the two links posted below... These forums are getting trashed by Tapatalk and externally linked images... You can, and should, do better...
Tapatalk Ad Removal
Image Uploading and Posting Etiquette
Tapatalk Ad Removal
sorry can't access the area to do the adsrad14701 wrote:Tinner22, please read and heed the two links posted below... These forums are getting trashed by Tapatalk and externally linked images... You can, and should, do better...
Tapatalk Ad Removal
Master Distiller
Why not...??? It's your phone, isn't it...???Tinner22 wrote:sorry can't access the area to do the adsrad14701 wrote:Tinner22, please read and heed the two links posted below... These forums are getting trashed by Tapatalk and externally linked images... You can, and should, do better...
Tapatalk Ad Removal
Yep, just can't find the setting.
Master Distiller
Can't find the dash board. Spent an hour looking at every function
Master Distiller
It's real easy to say go here and it's all there and it's not soooo
Master Distiller
Gee, I just installed Tapatalk on my Android phone and found the setting in under a minute... Can't be any harder on an iPhone... Settings > General > Signature > None... Done...!!! Now to uninstall the App again because I'll NEVER use it...Tinner22 wrote:It's real easy to say go here and it's all there and it's not soooo
I found the signature fine it's the ads I can't find to stop
Master Distiller
The Ads that you see are a bit trickier from what I've read... Might be easier with the Pro (purchased) version if you don't have that... Can't say for sure... Perhaps the existing Tapatalk topic or another (more likely) would be a better place to continue such discussion...Tinner22 wrote:I found the signature fine it's the ads I can't find to stop
Edited to add: THANK YOU...!!!
If you follow the link in Tater's thread, you'll be taken to a tapatalk blog. In it, it says to go to the tapatalk dashboard, "monitization" page and click, "disable". Then close tapatalk and restart. The ads should be off.Tinner22 wrote:I found the signature fine it's the ads I can't find to stop
tapatalk is one of those parasite host websites that I avoid like the plague (that they are). They are paid for by the ads they attach to all the members' communications....talk about "big brother's" control! I can do without it. But my question for the users, "what does the app do that is good for you?". I don't see any goodness.
edited to add: sorry for the derail TedL.
How about letting loose on The OCD issues of the need to pick and chastise on words,and lets get back on topic!
Going to build a dephlag this weekend for my 4" column using 3" copper cut and flattened. Then cut two 3.875 circles and 7 1.875 holes for 1" copper it'll finish 6" then I'm going to make a 4" piece for marbles 7" long. Then I'll run my gum head Sunday for some good ol gin
Master Distiller
