Safety switch
Safety switch
Had an (almost) accident once and thought the possibility of actually blowing myself up doing this was worth some pondering. I've red articles and posts on this site about what can happen and talked to someone who actually had an explosion (albeit on a gas driven still).
The theoretical scenario I've had described to me goes somewhat along these lines: Old man Jon eventually goes down to the cellar to check how his spirits are fearing. Since It's the second run of this batch and the boiler contains a 30% solution of mostly spirits and water the resulting gas is odorless. the still did not have enough cooling and is now effectively a bomb. Once the old man realizes this he either lugs out the contact from the socket or flips the switch on the still. A spark is generated and the still explodes. Even if he had realized it before it might have gone off from the spark of the light switch.
The conclusion is that it's simply to dangerous to do this without proper safety measures. I've therefore decided to build a safety switch for my still. It will be based on the arduino. I just wanted some input on this before i went ahead and put it together.
I'll be using the arduino mini. I've ordered a gass sensor on the cheap from here: http://www.ebay.com/itm/MQ-3-Alcohol-Et ... SwI3RW9Bmq" onclick="window.open(this.href);return false;" rel="nofollow
The switch that will connect and disconnect mains voltage to the still needs to not generate a spark or weld so i went with this solid state switch: http://www.ebay.com/itm/SSR-40DA-40A-25 ... SwPCVX~JED" onclick="window.open(this.href);return false;" rel="nofollow
The plan is to have the mains voltage cut when a certain reading is detected from the gas scensor.
Re: Safety switch
One of the rules we have is "Never leave a still unattended"
However I'm sure we all pop out for a carp or to brew a cuppa sometimes, so perhaps there's a place for it. The downside as I see it though is that it could lead to complacency and a desire too "automate" the art. I'm also wondering how you'd test it ?
Re: Safety switch
Well i'll be reviewing the possible readings of the ethanol sensor before setting the cutoff point. I thought i'd do this with a small amount of spirits and something to heat it. I'll be testing the sensor on all concentrations of vapor here.
The rest of it will have to be tested on different levels of output from the main element to make sure the switch is reliable. i recon the biggest possible cause of failure in this project might be my code so i will need to test it in a few plausible scenarios.
Re: Safety switch
In the scenario you describe, the still would not have exploded as it would not have contained any oxygen for combustion. The explosion would be in the room.
Re: Safety switch
A temperature switch reading the condensate temperature can be used to set off an alarm and/or trip a latched relay, cutting the power or closing a gas solenoid valve.
Re: Safety switch
Guess that's trueNZChris wrote:In the scenario you describe, the still would not have exploded as it would not have contained any oxygen for combustion. The explosion would be in the room.
Essentially does the same thing as the ethanol sensor except the sensor will be able to detect leaks elsewhere on the still. I'm not sure if i want to put a valve on the output of my still for three reasons: Don't know what they're made of, More complicated and cumbersome than having a modular ethanol sensor and I don't think sealing the still is a good idea.NZChris wrote:A temperature switch reading the condensate temperature can be used to set off an alarm and/or trip a latched relay, cutting the power or closing a gas solenoid valve.
The current design plan is to make a box that i plug in to mains of which i can then plug the still to. I'll have a lamp neck to position the sensor in close proximity to the output.
Re: Safety switch
That was not what was being suggested. It meant a solenoid valve in the gas line to a propane burner.RippoZero wrote:I'm not sure if i want to put a valve on the output of my still for three reasons....
Re: Safety switch
A latched relay in the box allows you to daisy chain as many checks as you want into the circuit, Ethanol vapor, condensate temperature, boiler pressure, boiler temperature, boiler level, dead man switch, receiver overflow, timers, whatever takes your fancy.RippoZero wrote:The current design plan is to make a box that i plug in to mains of which i can then plug the still to. I'll have a lamp neck to position the sensor in close proximity to the output.
- Truckinbutch
Re: Safety switch
'Never Leave A Still Unattended' is a mantra that can never be repeated enough . As folks that have been to my place can attest ; I am never beyond 3 steps from my still when it's running . Doesn't take that long to shut down if you have to leave . If you walk away from one running , what guarantee do you have that you will return ? NONE !Pikey wrote:One of the rules we have is "Never leave a still unattended"
I also have an established communication protocol with SOH . If I should ever fail a checkin she will be straight to the still house fully trained on how to shut it down and then deal with whatever issues I might be having .
Re: Safety switch
I agree its needless. Watch your still. Problem solved.
I thought i was wrong once,
But then i found out i was mistaken.
Kill the women, and rape the men.
Re: Safety switch
If i was using gas that would be the way to do itNZChris wrote:That was not what was being suggested. It meant a solenoid valve in the gas line to a propane burner.RippoZero wrote:I'm not sure if i want to put a valve on the output of my still for three reasons....
I can make the solid state relay latched using the arduino. my thinking is that once the threshold for cutting the power is met it stays out until i manually press a button to re-open the relay. besides i think it's safer to use the solid state relay since it only let's through current if the arduino energizes it. That way if the arduino for some reason dies, the relay shuts.NZChris wrote:A latched relay in the box allows you to daisy chain as many checks as you want into the circuit, Ethanol vapor, condensate temperature, boiler pressure, boiler temperature, boiler level, dead man switch, receiver overflow, timers, whatever takes your fancy.RippoZero wrote:The current design plan is to make a box that i plug in to mains of which i can then plug the still to. I'll have a lamp neck to position the sensor in close proximity to the output.
Re: Safety switch
I fail to see how automating the art is a downside. I myself often pop off to get a coffee or something new to read while the still is running. I just think it's a bit naive to assume that we are 100% fail proof cause we're not.Truckinbutch wrote:'Never Leave A Still Unattended' is a mantra that can never be repeated enough . As folks that have been to my place can attest ; I am never beyond 3 steps from my still when it's running . Doesn't take that long to shut down if you have to leave . If you walk away from one running , what guarantee do you have that you will return ? NONE !Pikey wrote:One of the rules we have is "Never leave a still unattended"
Re: Safety switch
Bashing automation and stomping on pot still thermometers are just HD cult mantras. Ignor them.
Re: Safety switch
RippoZero wrote:Had an (almost) accident once and thought the possibility of actually blowing myself up doing this was worth some pondering. I've red articles and posts on this site about what can happen and talked to someone who actually had an explosion (albeit on a gas driven still).
Two things I see. Left unattended and in a cellar which chances are/were, stale air without a draft.
Alcohol is proof God wants us to be happy.
Re: Safety switch
Thank you for the feedback everyone. It's much appreciated . I've started building the thing with the parts i have at hand for the moment. Found a fan controller in the barn with a suitable case. What you see on the table there is the power supply for the still and the arduino.
Re: Safety switch
The black knob adjust the power supply to the still. Thinking about adding a display and some kind of power measuring circuit so that the arduino can calculate how many watt the still is using. For now i will just have to measure voltage and current and find out at what possition the knob is in when 500, 1000 and 2000 watt is delivered.
Bellow is the code for the device. If anyone wants me to comment or explain anything, just ask. I can also give you the source of the parts i used if anyone is interested.
Code: Select all
void setup(){
void loop(){
safetySwitch();
void safetySwitch(){
const byte resetButton = 8;
const byte relayPin = 13;
pinMode(resetButton, INPUT);
pinMode(relayPin, OUTPUT);
byte buttonState = digitalRead(resetButton);
byte relayState;
int ethanolSensor = analogRead(A0);
if(ethanolSensor > 45){
relayState = LOW;
digitalWrite(relayPin, LOW);
if(buttonState == HIGH){
relayState = HIGH;
digitalWrite(relayPin, HIGH);
Serial.println(ethanolSensor);
- Truckinbutch
Re: Safety switch
You will never find that shit in my still house . Case to point :
Severe thunderstorm blew over my house today and caused a power outage too brief to kick in my generator . It did , however , require rebooting and reprogramming all electronics that we had in play at the time .
All my stillin equipment is hands on and will remain so .
- Swedish Pride
Re: Safety switch
nice work lad, could not even start to try to wrap my head around it but looks cool and sounds like it works well
I've a more basic set up for lack of knowledge and funds, not because I'm an old codger like TB
Don't be a dick
- Still Life
Re: Safety switch
Old electronics builder here. If I had an Arduino in my day I'd rule the world. They can be programmed to do anything.
Nice code work and nice build. Nowadays I admire electronics from afar, standing next to a still.
You've got the best of both worlds right there.
Don't worry about the naysayers. I still have close friends who are POSITIVE my still is a boiler bomb waiting to explode.
It's all in what you know and how you use it.
Re: Safety switch
The little automation I have restarts with no problems. I ran for decades with no automation, but now the price of controllers to make a distiller's life easier is so cheap it's hard to ignore. The controller looking after the Leibig of my Charantaise setup saves so much water and hassle I should have done it years ago, and would have if I had been paying for the water.Truckinbutch wrote:You will never find that shit in my still house . Case to point :
- Kegg_jam
Re: Safety switch
Question on the code.
I thought you were supposed to define constants and pin assignments in the Setup() routine....
Seems to me you are redefining your constants every time through the loop() instead of just once in Setup().
Re: Safety switch
I've accounted for that by making the switch default to OFF upon a startup. if the power were to fail the arduino would restart and open the supply of power only if i push the big black button.Truckinbutch wrote:You will never find that shit in my still house . Case to point :
It's not as hard as it looks. I recon you would be able to put one of theese together nicely with propper documentation from my side. the biggest challenge when someone has done something like this before you is getting the wiring right. the code is just copy paste.Swedish Pride wrote:nice work lad, could not even start to try to wrap my head around it but looks cool and sounds like it works well
I don't worry to much about the nay sayers but i do take their points into consideration. Having a still be run by shady and twisty hobby electronics is defenetly a bad idea for most people. That is part of the reason why i've started out by making safety features.Still Life wrote:Old electronics builder here. If I had an Arduino in my day I'd rule the world. They can be programmed to do anything.
I agree. Thinking i might automate the wash process a bit for my next build. still something i need to read/check up on thought. No reason to reinvent the wheel every time.NZChris wrote:The little automation I have restarts with no problems. I ran for decades with no automation, but now the price of controllers to make a distiller's life easier is so cheap it's hard to ignore. The controller looking after the Leibig of my Charantaise setup saves so much water and hassle I should have done it years ago, and would have if I had been paying for the water.Truckinbutch wrote:You will never find that shit in my still house . Case to point :
Re: Safety switch
Nice one - could you use the same kit to switch off if your boiler went over pressure ? or would you need to build another ?
Chris - does your water controller just switch on / off ot does it do variable flow adjustment ?
Re: Safety switch
I think i read something somewhere that it did not matter where you defined your constants in c#. i might be wrong though. I've started doing it this way to keep track of them in bigger sketches. when you start having four and five of these methods in one sketch the amount of backtracking to find out where everything goes gets ludacris. The best allternative might be to declare them as global variables and put them above the block of code they reppresents like this:Kegg_jam wrote:Question on the code.
Code: Select all
void setup{
void loop(){
safetySwitch();
byte relayState;
relayState = LOW;
relayState = HIGH;
Re: Safety switch
On/off, but with a reservoir which acts to smooth the on/off effect.Pikey wrote:Chris - does your water controller just switch on / off ot does it do variable flow adjustment ?
Re: Safety switch
That could be done but it would require me to install a preassure sensor somewhere on the still and run some detachable wire between the arduino and the sensor.Pikey wrote:Nice one - could you use the same kit to switch off if your boiler went over pressure ? or would you need to build another ?
Re: Safety switch
Rippo
Nice one mate and any protection is good .
I like your thinking on using a SSR to switch the power to avoid potential sparks
But .... having been an electronics tech for over 30 years and replaced thousands of semiconductors , transistors , SCRs and Triacs that have gone short curcuit I would not place my life on one .
Do you have a way to check that the SSR is functioning everytime you use this ?
Or even operate a remote contactor on the switch board .
Re: Safety switch
I have considered doing a multi-point safety shutdown, not so i can leave but rather so it can shutdown automatically before i have a chance to lift my ass off the chair.
3 weeks ago about 4 hours into a run everything was stabilized i was in the middle of hearts and nothing had varied for hours.
thought i'd make a double check of everything and sneak out for quick minute and be right back...walked over to the still from about 10' away, glancing down at the steam valve, which was right was where it was supposed to be and when i looked up the output started blowing vapour -hard...
slapped the "near" holyfuckswitch (there are 3 wired in series about the shop) and watched the still evacuate vapour for about 2 minutes as the jacket cooled.
went about my business and when i got back in a couple minutes i fired it up again and completed the run without incident without varying anything on the system. I have no idea what caused the vapour spewing. Looked and looked but nothing was askew. Can only guess it was a vapour lock in the deflag or PC that caused cooling water interruption.
so maybe an alcohol detector would have shut it down or maybe the air current would have dragged the vapour in the direction of the fire instead of the detector. who knows.
some glad i was there to shut it down and it certainly reinforced why i never left before...and ain't gonna leave in the future.
now i drink for evil.
Re: Safety switch
You're right. Having the solid state relay short circuit does represent a potential fault. I do have a fuse in the thing that goes at 250 volts and 10 amperes or 2500 watt. This is well below the rated maximum for the relay. Is this a good solution? I do get to personally check if the relay can open and shut properly every time I start the device. while the sensor is heating up for about 15 minutes the only way to open the relay is to hold in the button. if I let it go in that period the sensor will detect a false positive and shut the relay. I think the part in this system that represents the biggest potential of failure is the MQ-3 gas sensor. Maybe I should double up on that and have 2 of them?Yummyrum wrote:Rippo
Re: Safety switch
Having a fuse is always a good idea but semiconductors generally destroy themselves in a fault situation quicker than a fuse blows .RippoZero wrote: You're right. Having the solid state relay short circuit does represent a potential fault. I do have a fuse in the thing that goes at 250 volts and 10 amperes or 2500 watt. This is well below the rated maximum for the relay. Is this a good solution? I do get to personally check if the relay can open and shut properly every time I start the device. while the sensor is heating up for about 15 minutes the only way to open the relay is to hold in the button. if I let it go in that period the sensor will detect a false positive and shut the relay. I think the part in this system that represents the biggest potential of failure is the MQ-3 gas sensor. Maybe I should double up on that and have 2 of them?
So long as you have a light across the element so you can see when the relay is supplying power ( either when its ment to or not ) and an audiable alarm to indicate the presents detected alcohol so that if you are not in theroom , you can here it and come quickly and double check that power has been cut would be a good thing .
Yes I think maybe a few sensors might be a good idea .Its common practise to have several smoke detectors in a house nower days so why not
