scrapping a freezer to make insulated box
Post your builds here.
Pikey
Post by Pikey »
I have a working chest freezer which is really old. It's been in the garage for 12 years working and I got it for nothing from a guy who was throwing it out 12 years ago, so I'm going to scrap it and hopefully use the sides and lid to make an enclosure for 2x 220 Litre olive barrels to ferment through the winter. I'm wondering whether this would work and how to form corners and joints if i have to cut and join.
The freezer is a 10.5 cu foot chest freezer, stands about waist high. The barrels are a little higher. :?
Tater
Re: scrapping a freezer to make insulated box
Post by Tater »
just ferment in freezer line with plastic sheet if ya think nessary.
Blarney Stoned
Post by Blarney Stoned »
You can add an extension above the chest if you need it taller. I’ve seen this done many times with “keezers”, where brewers turn them into kegerators by adding a 2x6 board around the top rim. Insulate it and seal it to the chest. Reattach the top hinge onto your extension. Often brewers add taps in the extension rather than risk damaging the refrigerant coil lines in the chest.
Need a foto? Google “keezer”.
here —> https://www.coldbreakbrewing.com/pages/ ... d-a-keezer" onclick="window.open(this.href);return false;" rel="nofollow
I f you wreck it, how are you going to cool it when a rampant ferment overheats?
Pikey
Post by Pikey »
Oh bugga :roll:
I spent all day plotting the wall layout with a mate - 2 big fermenters - preheater up high, still lower, thumper, - all sitting in /on / under Dexion racking :D - All I need to do is lose that freezer and insulate the fermenters - Hey wait, I can use the insulated sides etc to box the fermenters in :D ANd still plenty of space for storage on the racking. :) - Got an old incubater I can use as a thermostat controlled heat source :D
Now thanks to you lot, it looks like I have to keep the freezer. I just measured the diameters of the fermenters and it looks as though they "Might just" fit in the freezer - then again knowing my luck it's more likely they "Just won't" :(
But, to make it work, I'll need to miss out one of the front legs. and I suppose when the lid is down I can use the top of the freezer as a workbench, But my storage on the racking is going down and the other equipment will be squeezed - if I can get it in. Actualy I may need to lose 2 complete bays of racking, which will lose a lot of stability :roll:
CAn't get to the freezer at the mo to open it, but I'll give this some more thought tomorrow. I'll give all the ideas a good thought for a while.
As for NZChris's question - I've never had a runaway ferment - Might be nice
Thanks for all your contributions Folks.
Pikey wrote:As for NZChris's question - I've never had a runaway ferment - Might be nice
You've never fermented in a well enough insulated box in summer to have a problem, but with decent insulation it can easily happen. I control the heating elements and compressor with one STC-1000 controller, controlling the temperature in the incubator, not the ferment.
+1 Chris. Your words were running around in my head.
Pikey
Post by Pikey »
OK lads - point taken - I'll leave the compressor and gas intact, if I can make the dimensions work :thumbup:
[EDit thanks ss - that adaption is now the target ! :thumbup: 8) ]
