Horny's firewood Maxi-ministill
hornedrhodent
Post by hornedrhodent »
Here's the pics
Underexposed image of complete still showing poor contrast between still and background trees
Out of focus image of complete still
Firebox waterjacket and boiler
Firebox and water jacket showing header tank for jacket
Boiler assembly
Boiler, lid and clamp ring
Ministill type head and cooling coil on top of column
Column showing copper packing and aluminium casing for rockwool insulation
Double 1/4" coils connected to 1/2" riser up centre
Hope that doesn't exceed any limits.
stoker
Post by stoker »
nice, that boiler makes me think about the real oldfashion moonshiners
is it wood heated? <edit>, stupid question, it was in the title :?
what's the inner boiler made of?
I have also a removable ministill head, looks like I'm not the only one.
and does it work propperly? do you have a draft or something?
-I have too much blood in my alcohol system-
copperhead
Post by copperhead »
whats the size of your boiler and is it stianless if so nice set up i really the old shinners way as long as its safe.
hornedrhodent
The boiler is stainless - it was a water filter - I had to cut a bronze casting off the bottom and silver solder a stainless patch over the hole.
The 2" pipe was a piece I found somewhere and had to panelbeat to get enough straight bits. I used a piece of steel exhaust pipe as a tool to expand the copper ends so the connections are a 'slip in' fit sealed with flour paste.
It takes a lot of attention to run on firewood. I added an extra thermometer where the copper comes out of the boiler lid to help prevent column flooding. It's surprising how small a fire is needed when it's up to temperature.
Sorry I made the pics too wide - I forgot to allow for the width of the column on the left hand side of the screen. I'll try to get it right next time.
All the info I needed to build it came from this forum and the homedistiller.org site. Thanks for the help everyone.
C.S.S. Shenandoah
Post by C.S.S. Shenandoah »
Beautiful still. This is the kind of still I like to see, it's kind of crude, in a good way. Just like the good old days.
hornedrhodent
Bump for Murphy
nanosleep
Post by nanosleep »
As the run progresses the alcohol content in the boiler should get very small. In this case the boiling point of the liquid in the boiler is almost the same as the boiling point of the water in the jacket. Do you have trouble getting enough heat into the boiler without boiling the water jacket dry? Ever tried another liquid for the jacket? Oil?
hornedrhodent
Things really slow down towards the end and the jacket may be boiling and producing steam before I've collected all the tails I want to.
I use a small header tank (about 1gal) to maintain the water in the jacket. (see background in 4th pic.) The output from the condenser goes into the header tank which overflows to the ground to maintain the watertable.
The idea of the water jacket is to increase thermal mass and even out temperature fluctuations with variable heat input (firewood) and to limit it more as the temperature increases. Water has a much greater specific heat capacity and a greater latent heat of evaporation than oils so does a better job. When your boiler gets to 100degC it's finished.
Rotgut
Post by Rotgut »
i love it i want to build something like that someday
Uncle Jesse
Site Admin
yep
Post by Uncle Jesse »
very nice, it gets my seal of approval
marryanne
Re: Horny's firewood Maxi-ministill
Post by marryanne »
I use a boiler machine.!but it made me think that making a new generated
Maxi-ministill bio fuel machine could be possible.
make money online
Esie
Post by Esie »
hi.''
regards,,''
Esie
how to deal with depression
