Newbie: Sugar wash has no alcohol
PIDnerd
Post by PIDnerd »
To break in my newly built 2" Bokabob still, I made up a wash using table sugar following a recipe posted by wineo. Followed it exactly except for the substitution of potassium metabisulphite for DAP (the store didn't sell it).
8 # sugar, 6 gal water, 1 tsp citric acid, 1/4 tsp gypsum, 1 tsp potassium metabisulphate. At 90 degrees, spread 1/4 cup of distiller's yeast, closed up the fermentation bucket & filled the airlock. Left the bucket in my guest bathroom tub for 2 weeks. It bubbled strongly for the first week, then tapered off. After 2 weeks, took off the lid & put in the hygrometer - it said 0% alcohol. To test the device, put it in some commercial hootch; read 90 proof as labeled. The wash does smell like it did at the Jack Daniels brewery I toured last month.
This morning, put it in the boiler & set the temp for 183 degrees. The boiler hit that in 50 minutes, but after 2 hours, the upper column is room temperature. I'm assuming that's because there's no alcohol vapor to rise. My plan is to let it run for another 2 hours. surely a proper wash would be producing by then.
So my question is: why didn't the wash ferment? Was the subsitution a mistake? Should the wash be kept at 80 or 90 degrees? Does table sugar not ferment? (MY questions about operating the still will be posted elsewhere).
Thanks in advance.
This topic has 18 more replies
Register Login
