A couple of clueless
N0 Clue_
Post by N0 Clue_ » Mon Sep 21, 2020 8:27 am
Hi! :wave:
My husband and I recently bought a second hand still and so we are hoping to give distilling a go, and looking forward to learning lots from you guys!
Thanks for having us! :thumbup:
Durhommer
Re: A couple of clueless
Post by Durhommer » Mon Sep 21, 2020 9:36 am
Pictures would be nice
Demy
Post by Demy » Mon Sep 21, 2020 9:41 am
welcome,It is a beautiful still.
N0 Clue_
Post by N0 Clue_ » Mon Sep 21, 2020 10:14 am
Durhommer, picture attached! :thumbup:
tombombadil
Post by tombombadil » Mon Sep 21, 2020 12:07 pm
Whoa! Very cool! Congrats!
dieselduo
Post by dieselduo » Mon Sep 21, 2020 12:37 pm
Beautiful ! That will make some nice whisky
Chauncey
Post by Chauncey » Mon Sep 21, 2020 12:57 pm
Youre gonna wanna get a larger reservoir for the cooling water
Post by Saltbush Bill » Mon Sep 21, 2020 1:21 pm
Biggest problem i see is the ability to make a clean enough base spirit for the gin.......for that part of the job a reflux still is a better option.
Demy
Post by Demy » Mon Sep 21, 2020 1:30 pm
That's right I think the same thing, it will take a lot of runs and there will be a lot of smudging. I also run small sizes and with those proportions I realized that some problems increase. My little VM column saved me!
N0 Clue_
Post by N0 Clue_ » Mon Sep 21, 2020 2:12 pm
Thanks so much guys for your thoughts and comments! This was the set up for the person whom we bought this from, its not ours. We need to do a ton more reading before we dive in.
As newbies, and in the UK, we are looking at buying in the base spirit to begin with.
Post by Saltbush Bill » Mon Sep 21, 2020 2:26 pm
In that case you are ready to make gin.
Durhommer
Post by Durhommer » Mon Sep 21, 2020 2:32 pm
See how posting pictures got you help this place is full of possibilities and positive people to help you reach your goals
corene1
HD Distilling Goddess
Post by corene1 » Mon Sep 21, 2020 7:50 pm
Very nice still. I would agree that a bigger cooling source would be a good idea. Maybe a plastic trash can. About the take off spout. Is that a plastic hose feeding a plastic parrot? I can't tell from the photo. If so take it off as the alcohol will leach chemicals and flavors from contact with the plastic.
Master Distiller
Post by NZChris » Mon Sep 21, 2020 11:32 pm
Welcome to the forum.
I've recently bought a very similar still to add to my collection.
Cooling water:
Heat rises, so add cold water to the bottom inlet and overflow the hot water to the drain, or collect it for your garden/whatever.
My first run, I used a tube and funnel to pour cold water into the bottom when it was needed.
My second run, I used a 12V temperature controller, with the thermocouple in the worm, and a solenoid valve to gravity feed the cooling water as needed. That was less hectic.
My next run will use the same 12V temperature controller, but using a tiny submersible pump.
