Controller double check
If it plugs in, post it here.
bcook608
Post by bcook608 »
So after doing some looking around, I decided to bite the bullet and dive in to the electrical world.
I have decided to modify my 5 gal stock pot still to run on an internal submerged element.
according to my math, this setup will generate 1625w of power @ approximately 14.78A draw which should be well within the 20A circuit I plan to use which is protected by a GFCI outlet.
I will be using the following:
Dernord 6500w ULWD Wavy Element
110v on/off switch - I'm going for a more industrial look for the switch
Auber DSPR1 Controller
Multimeter Ammeter/Voltmeter
Auber 40A SSR
Heatsink
10"x7"x4" Junction Box
110v 60mm Cooling fan - x2
I will be wiring everything together by repurposing a 25ft 10/3 extension cord which should give me more than enough wire to work with, plus it has factory connections on each end. I haven't decided if I want to wire direct to the element or give it a little pigtail and plug it into the female end of the cord.
Here is the diagram that I have put together for wiring. I am unfamiliar with the wiring of the DSPR1, but it seemed like the best option to go with. I know I don't NEED the multimeter/Ammeter/volt meter, but I like to have as much info as possible and this gives me multiple frames of reference to ensure I can repeat the process. Please let me know if I don't have things wired up the right way. I have ordered the parts listed above and as they start to show up, I will begin assembly. the layout may change over time, but I want to make sure my research into the wiring of everything has led me to the right conclusions.
This topic has 90 more replies
Register Login
