The issue I read here and other places is people’s complaints on how long spirit runs take and not enough time etc. A smaller port on the offtake slows down the rate of output if runtimes are an issue. It does however increase the reflux ratio for higher purity. But if you are already getting highest purity why then would you want to throttle the rate of output.Yummyrum wrote: ↑Fri Aug 04, 2023 3:08 pmIndeed , but when do we ever need it ?kimbodious wrote: ↑Fri Aug 04, 2023 2:42 pm. A smaller port at the offtake increases the reflux ratio thereby reducing the output rate.
When running in reflux mode , invariably it’s to make neutral and with such a high Reflux ratio that again port size is not an issue .
I’ll digress. My mate has a 2” diameter column on his CCVM but it only has a 0.5” offtake. He never has to move the RC because the reflux ratio is being set by the very small offtake. He has no trouble at all getting two drips a second at the highest purity BUT that is about as fast as his still runs!
