sterilizing
sterilizing
Just doing a check to see what every one is using to sterilize there equipment with ? I my self been using sulfate solution because it is cheap and you do not have to soak your stuff or have to rinse for years in my brewing and wine making and have never had a problem with infections.
Maybe others have new ideas.
diluted chlorine bleach
I've been straight-grain brewing for over 20 years, and I use a dilute solution of chlorine bleach...usually the cheapest store-brand I can find...usually a couple of ounces in a gallon will do for a short (5 min) soak.... Read Papazian's "The complete Joy of Homebrewing" for more methodology...never has failed me.
I get a rag and some hydrogen peroxide or really bad hootch and use it. The peroxide will break down into oxygen and water and the alcohol will evaporate. Never a problem.
"If you can't dazzle them with brilliance... baffle them with bullshit."
"Don't steal. The government hates competition."
"Believe none of what you hear, and only half of what you see"
20lt small pot still, working on keg
This is what I've been doing - same screen name
http://www.realbeer.com/discussions/sho ... adid=16206
you need a 30 second contact time I don't think that's mentioned in the link. There's even more info about it in the podcast.
http://www.basicbrewing.com/index.php?page=radio
scroll down to "March 29, 2007 - Sanitizing with Bleach and Star San"
"Hey guys... I don't think sitting on a rooftop drinking ram's piss is the way to go."
I just clean everything with hot soapy water as soon as I get done with it. Some times I just dump more sugar and hot stillage into my mash buskets, top it off with water, yeast and keep right on going. If you don't leave anything sitting around dirty then the risk of spoilage is greatly reduced. Some of the old time distillers were terribly dirty and they seemed to produce some good shine.
Yes, I sometimes think the sterilising thing is taken too far. If you wash things well in hot soapy water, rinse with clean water, and let them dry completely, that takes care of pretty well everything you have to worry about.shadylane wrote:Some of the old time distillers were terribly dirty and they seemed to produce some good shine.
Be safe.
Be discreet.
And have fun.
Be discreet.
And have fun.
- Site Admin
bleach
I've heard that bleach can react badly with stainless steel and cause pitting over time.
Not sure whether or not it's true but if not, bleach is hard to beat for cost and effectiveness. Also it goes away pretty nicely when you dry it out.
Re: bleach
Anything with chlorides/chlorites in it, such as bleach, or hydrochloric acid, etc, is no good for stainless, especially for prolonged exposure.Uncle Jesse wrote:I've heard that bleach can react badly with stainless steel and cause pitting over time.
Be safe.
Be discreet.
And have fun.
Be discreet.
And have fun.
Re: bleach
I heard this too, but I thought "no way it's stainless, bleach won't hurt it". Well I soaked my stainless handled carboy brushes in a bleach water solution (1 tablespoon per gallon) and the stainless has lost it's "shine", they feel slightly rough to the touch and have a whitish film to them.Uncle Jesse wrote:I've heard that bleach can react badly with stainless steel and cause pitting over time.
So I don't use bleach solutions around stainless anymore.
Towering in gallant fame,
Scotland my mountain hame,
High may your proud
standard gloriously wave,
Land of my high endeavour,
Land of the shining rivers,
Land of my heart for ever,
Scotland the brave!
High may your proud
Scotland the brave!
steaming faster than boiling?
They say steam is hotter than boiling water, so I thought less water to bring up to boil, and hotter temps. I tried sterilizing things in the past by keeping them above water level in a BOP. I'd put about three inches of water in the pot, fire it up with a lid on and let it go as long as I felt was thorough enough.
Anyone think this might work better/faster than boiling?
A1 to Portland on #19
You're on the right track for making a home autoclave! Autoclaves use a pressurized chamber and steam to sterilize stuff. I remember reading somewhere that you can use a pressure cooker to act as an autoclave. I think you put the items to be sterilized in a vegetable tray or something to suspend them above the water line and cook it. The pressure cooker will pressurize and fill with steam and will be hotter than 212 deg F. I think this was done for 15 minutes but I'm not sure, I read about this a long time ago.
High may your proud
Scotland the brave!
High may your proud
Scotland the brave!
I just pick up whichever quat sanitizer is cheapest at the local restaurant supply store. Right now that's Ajax commercial. Pick up any non-chlorine based "rinseless" sanitizer. I recently attended a food safety class and these sanitizers are what they recommend too. Buying StarSan and other brewing specific sanitizers is way too expensive for me. Chlorine isn't good on stainless and you have to rinse with water which can re-infect your stuff.
I make my own beer
and wine
Some hits the still
for 'shine
and wine
Some hits the still
for 'shine
Stillsmokin wrote:
Hope this helps.
Steam can't be hotter than the water it boils off from. Actually it may be slightly cooler due to the energy released during the transfer from liquid to steam. But, the autoclave operates a a higher temperature due to the increase in pressure. Water boils at 212f in a container open to the atmosphere but an autoclave at 15 psi will boil water ~257f. An autoclave and a pressure cooker are the same thing, autoclaves just cost more because they are a "specialized" piece of equipment. They make portable autoclaves for emergency responses like a mass disaster team that might have to operate under conditions with out electricity (plane crash in the middle of the woods) that can be heater directly by fire. These are just glorified pressure cookers.They say steam is hotter than boiling water
Hope this helps.
Fire is the devil’s only friend - Don McLean
Jump in where you can and hang on - Brisco Darling
180 DEG water will sterilize. Ever work resturaunt where that is what they used. The US Navy uses the hot water method in their galleys as well.
Used to see who could snatch a spoon or fork from the bottom of the sterile sink without getting hurt. LMAO i was pretty quick handed but others were not. Funny
Read Please, Try it, Learn!
hillbilly autoclave
Maybe next time I'll set a brick on the lid. hillbilly autoclave?You're on the right track for making a home autoclave!
Actually its sanitize not sterilize. See here:
http://www.bodensatz.com/staticpages/in ... sanitation" onclick="window.open(this.href);return false;" rel="nofollow
Using hot water works well. There is also a relationship between the temperature of the water, how long it is in contact with the thing you want to sanitise/sterilise, and how well it sanitises/sterilises. Boiling water sanitises almost instantly, and only takes a few minutes to guarantee sterilisation. Lower temps take longer. But no microbe we have to worry about in fermenting survives even 50ºC water for very long. If it is too hot for you to leave your hand in, it is too hot for any (signficant number) of those microbes to survive in.
When I am mixing up a ferment, or taking sample from a ferment, I just clean my (glass, plastic, and stainless) measuring and stirring equipment with hot water and detergent, and then rinse them with hot tap water (about 60C) straight out of the tap for about 20-30 seconds. Haven't had an infected ferment yet (fingers crossed).
I do use a commercial cleaning/sanitising powder from the brew store for the fermenting barrel itself.
Be safe.
Be discreet.
And have fun.
Be discreet.
And have fun.
Sanitizing and sterilizing are 2 different things. Sanitizing (ie with chemicals, pasteurization temperatures 140-180 deg, etc) just reduces the amount of organisms on a surface to a point were the yeast will be done fermenting the sugar before the bacteria/organisms build their colony back up.
Sterilizing (ie autoclaves, direct flame, boiling under pressure) will kill EVERY last living cell on a surface. Used for surgical equipment, in laboratories, etc. We as home distillers, brewers, or vinters don't need to sterilize our equipment, sanitizing is enough for our purposes. The only time we may need to use sterilization is if we were managing our own yeast colonies and or saving yeast for many, many generations. It couldn't hurt to sterilize our equipment, but the extra effort is not entirely necessary.
High may your proud
Scotland the brave!
High may your proud
Scotland the brave!
http://en.wikipedia.org/wiki/Sterilization_(microbiology" onclick="window.open(this.href);return false;" rel="nofollow)
Hey but as soon as you take it out of the auto clave isnt it germed up?
i work for the Canadian Food Inspection Agency, Its really Animal Disease And Research Institute we just cover it up with CFIA so the animal lovers arnt on our case to much... anywasy we have about 20 Autoclaves in the building. So i will answer some of the questions brought up. Steam IS hotter than boiling Water, Autoclaving IS like a pressure cooker to a degree but i dont know too many people that can stick the columns, heads, and boilers in a betty crocker presure cooker...On the weekends when i want to work i bring my coloumn, nixon head in and autoclave it at 150 C...any hotter youll ruin your solder points. as for the keg its self alittle soap and water...DO NOT USE BLEECH. In the Labs thats what we work with. Its in our S.O.P's to bleech all the counter tops at the end of they day. Over time it completly ruins the stainless steel counter tops and we replace them... so yes thats where your tax dollars go.
Less Chattin More Drinkin
