How the Body Processes Alcohol
Most alcohol is absorbed from the stomach, where only a small amount is broken down or metabolized. The alcohol next passes through the liver where it is broken down by an enzyme known as alcohol dehydrogenase to a compound called acetaldehyde.
Acetaldehyde causes some of the unpleasant effects of alcohol, such as
flushing, nausea, and vomiting. Acetaldehyde is subsequently broken down by aldehyde dehydrogenase to acetone, which is eliminated in the breath (the smell of alcohol on the breath), urine, and sweat. People with low levels of aldehyde dehydrogenase have a condition common in some individuals of Asian origin, which is characterized by flushing or feeling ill after drinking only small amounts of alcohol. Not all of the alcohol is broken down in the liver during its first pass. Some of the alcohol reaches the brain. The effects of alcohol on the brain are well-appreciated by most people. Eventually, all of the alcohol is eliminated from the body.
In people who drink heavily and on a regular basis, alcohol stimulates an alternative metabolic pathway in the liver (mixed-function oxidase enzymes). Metabolism of alcohol via this pathway may make conditions
adverse for liver cells. Stimulation of this alternative metabolic pathway
is also one reason why alcohol-dependent people have to drink more to get drunk. Tolerance to alcohol also develops because chronic heavy drinkers learn how to behave better while drunk and their brains need to see higher concentrations of alcohol to be affected.
Over the liver and through the woods.
This is not correct.Rocky_Creek wrote:Acetaldehyde is subsequently broken down by aldehyde dehydrogenase to acetone, which is eliminated in the breath (the smell of alcohol on the breath), urine, and sweat.
Code: Select all
from "How Alcohol Works"
by Craig C. Freudenrich, Ph.D.
How Alcohol Leaves the Body
Once absorbed by the bloodstream, the alcohol leaves the body in three ways:
* The kidney eliminates 5 percent of alcohol in the urine.
* The lungs exhale 5 percent of alcohol, which can be detected by breathalyzer devices.
* The liver chemically breaks down the remaining alcohol into acetic acid.
As a rule of thumb, an average person can eliminate 0.5 oz (15 ml) of alcohol per hour. So, it would take approximately one hour to eliminate the alcohol from a 12 oz (355 ml) can of beer.
The Breakdown of Alcohol
The breakdown, or oxidation, of ethanol occurs in the liver. An enzyme in the liver called alcohol dehydrogenase strips electrons from ethanol to form acetaldehyde. Another enzyme, called aldehyde dehydrogenase, converts the acetaldehyde, in the presence of oxygen, to acetic acid, the main component in vinegar. The molecular structure of acetic acid looks like this:
O
H3 C - C - O - H
The || symbol is a double bond between the atoms. When ethanol is oxidized to acetic acid, two protons and two electrons are also produced. The acetic acid can be used to form fatty acids or can be further broken down into carbon dioxide and water.
