Not quite. I get something off that doesn't smell like anything you describe and when I run it I get tails coming over after the first 250-300 ml and through the rest of the run.jb-texshine wrote:So if I've comprehended this post correctly...some of you are getting fermented washes that smell of sulfur? Like garlicky,sweaty armpit sulfonamides smell? In the wash?
Read a long time ago about wine faults and the penny test. By process of deduction, as explained in a run down of that test, if you drop a copper penny in a faulty glass of wine and the fault disappears then the culprit was sulfur.
I dropped copper into a wash with this fault, let it sit and it cleared up.
That is where it's at and nothing anybody says is going to change that.
The question that remains is, is copper exposure in an all copper still enough exposure? That sounds like, how long is a piece of string? It is a moving target and nobody has the answer.
But I can build an all copper still and hope, place copper in key spots on my existing still and hope or I can park my wash for a day with copper in it and be sure. You can do whatever pleases you but I'm going to go with no. 3, even if it takes the romance out of the process.
Now the next part is pure speculation on my part but I started thinking that if I was getting tails within the first 500ml of distillate, for whatever reason, from a typical 5 gal charge and looking at the boiling points of congeners and descriptions of "normal" runs the question that came to mind was, what makes tails "tails"?
The description sounds a lot like what wine guys call cork taint but I know I don't use cork so where does the "wet newspaper, dank basement, wet shaggy dog and musty" come from and, in my case, why was it coming over so early in my runs?
