Thumper, condenser elevation conf. for flavor and abv
1RiverRunner
Post by 1RiverRunner »
Edited: I was wondering the effect of some of these angles/elevations on flavor and abv?
Last edited by 1RiverRunner on Thu Jul 18, 2019 10:28 pm, edited 2 times in total.
Re: Thumper, condenser elevation conf. for flavor and abv
Why is this thread in this forum? It seems to be misplaced.
Can a moderator move it to the appropriate forum? Hopefully, it will get some responses then.
acfixer69
Post by acfixer69 »
Let's try it here :P
1RiverRunner
Cool. Thanks for the move!
acfixer69
Post by acfixer69 »
Don't believe you are going to get an answer as you don't ask a real question that has specific answer. Good news is read the basics and the answer will be seen.
1RiverRunner
Maybe not. I edited question.. t’ see how that does.
If there is a difference to be had, it will be by having the lyne arms rising or falling, but those lyne arms might be too small a diameter to make a noticeable difference.
Kareltje
Post by Kareltje »
I have seen an article once comparing the angle of the lyne arm and the taste of whiskey of several Scottish distilleries. There was no clear outcome, if my memory serves me well. But of course there were much more variables in comparing live distilleries.
I guess you have to try if you want to know. The effect on abv can easily been measured. On taste will be more difficult as you will need a standard beer or wine to start with.
Let us know what you find.
I heard that a rising lyne arm made lighter flavored product than a falling lyne arm. My current still head build gives me the choice of both.
1RiverRunner
Could you infer that if your lyne rose out of the still, but was angled down from the thumper, that your thumper flavors would stand the best chance of being most prevalent, given all other factors aside?
I'm inferring that if you want to notice a big difference, you will need larger lyne arm diameters than in your pics, or run very slowly.
What do you want to accomplish? Light flavors, or full flavors? Long aged, or instant gratification?
1RiverRunner
Probably all of those goals at one point or another.
Corsaire
Post by Corsaire »
My take on this: it doesn't matter. Not on a hobby scale anyway.
The theory is that in a rising lyne arm vapor condenses and falls back into the pot or thumper. Which would up the reflux and make a lighter product.
On a hobby scale the diameters and length of the lyne arms are small. So there's not a lot of metal to soak away heat and produce significant reflux.
However, maybe somebody with a modular setup could try this and measure temps along the way. I could be wrong in my assumption. It's happened before. I can't test this, I only have a simple potstill with fixed lyne arm.
1RiverRunner
Thank you for the feedback guys. Was away for awhile.
