Iulistoi wrote: ↑Mon Mar 22, 2021 7:46 am
I just want to know when It floods, I didn't said flooding is the worst nightmare.
Flooding occurs in a reflux column when one of these is out of balance.. to much power used, the packing holder is restraining / holding liquid from dropping down, the packing used is overpower by the vapours, or the RC inability to knock down the vapors, and a combination any two them..
Knowing when a column is flooding is easy to recognize, distillate / liquid is coming out the open top.. as to the why that occurred can be the result of a few things..
If the loading of the column up at start is to fast, in other word not reducing / adjusting power until after the vapors have broken through the packing, flooding will occur as the vapors are overpowering the RC..
If power is reduced prior to the vapors braking through and stabilization has started and flooding occurs, then the packing holder is the issue, as the packing holder is holding the distillate in the column..
Knowing where or when flooding will occur with a unit, and each one are different as will as each run will be also, requires to start by stabilizing the column, then slowly increase power, like a quarter amp at a time, allowing time for the reaction to occur, making sure the RC is maintaining its ability to reflux, and repleting this power increase until the vapors overpower the RC..
Knowing where those limits are will be different for each unit, note taking is important for future runs, as each run will also be different in power usage and water flow..
I prefer to limit the adjustment of water to the RC as there is a point of no return beyond a certain water flow rate.
As to HETP of any kind of packing used, personally I have no interest in knowing such, as I don't run the reflux column using that info.. from experience with the units I have, and the notes, I have learned to run in the semi flooded state.. but the task of each operator of still, is to find that state for his unit..
Mars
