Mulberry wine help
Mulberry wine help
A friend wanted me to help them make some Mulberry wine and it has not started fermentation I need help diagnosing the problem. First this is what I did.
I had 8.7 lb of mulberries crushed.
pectic enzyme
Wine tannin
yeast nutrient
Acid blend
Campden tablets
After I added the campdem tablets (3) I waited 24 hours before I pitched the yeast everything was stirred prior to pitching the yeast to aerate the must. After adding the water everything came up to a volume of 3 and 1/2 gallons. I pitched last night with 5 grams of Montrachet yeast. This morning I have no signs of fermentation. I'm not saying that it's not fermenting because the lid that I have might be leaking, it's not believed that came with the fermentation bucket so I had to make due. I think it's a little too early to try to take a gravity reading to see if it is changed . What could be wrong or does it typically take longer to get started? I haven't done any wine in 30 years so I don't know what to expect.
I forgot this morning I added a heating pad to the must to see if I could get the temperature up but then I researched the yeast and it's good from 50 or so degrees to 89 so I think I'm good there.
pectic enzyme
Wine tannin
yeast nutrient
Acid blend
Campden tablets
- GreenEnvy22
Re: Mulberry wine help
It's not uncommon to not see any active fermentation for upto 48 hours, so don't worry yet.
Your sulfite levels are higher than I'd use before fermentation (I'm guessing around 60ppm), which may cause problems for the yeast.
I'd have only added 1.5, aiming for 30ppm, most commercial yeast can tolerate that, but its enough to protect the must.
I have a 50L pot still with dual Liebig condenser.
I typically make Whisky, grappa, and brandy.
The only reason I added it that much was because the package said one per gallon and to wait 24 hours after doing that.
Was the temp of the must at the time of pitching, plus was the yeast sprinkle or stirred in or proof and stirred in.. and the addition of 3 tablets of campden was on the high side, as stated, yeast do not like a high sulfide environment ..
The yeast used has a wide range of fermenting temp, and it's mid range would be about 75 - 77*F, and would my targeted fermenting temp..
All the wines I made, the yeast was just sprinkled on top, and would take about 1.5 days to starting using sign of fermentation.. so just over night is nothing to be concern yet..
As to having the fermenter seal, it's not a requirement in the first stage which the production of alcohol, but it's important to have it under an air lock in the secondary stage and on forward.. oxygen it the enemy of wine..
Mars
– Albert Einstein
– Albert Einstein
Okay thanks guys it was room temperature at time of pitching the yeast and it was just sprinkled on top also I did add 5 lb of white sugar to bring up the gravity points to 1.080 I guess I'll give it another day or so and see what happens.
I'm confused by your respond, but let see if I understand it right..
The addition of white sugar, was that done before the yeast was pitched or after.. and what does "room temperature" mean in actual number..
If you sprinkled the yeast, it should be visable on top of the must and show sign of proofing itself..
Mars
– Albert Einstein
– Albert Einstein
Okay when I got the recipe together I forgot to mention that I added 5 lb of white table sugar. Yes the sugar was added before the yeast. I mixed all the ingredients up and added the campden tablets and then let it sit cupboard with a mesh Brew bag for 24 hours. The room temperature in my house stays anywhere between 75 to 72 degrees constant. Before I sprinkled the yeast on top of the must I gave it a vigorous stir with a spoon.
Ok.. so is the yeast visible on top of the must, as it was sprinkle, there should be signs of proofing.. and the ambiance room temp would be ideal for fermenting..
Quote.. "Before I sprinkled the yeast on top of the must I gave it a vigorous stir with a spoon." was the must still in motion or allow to become still before the yeast was pitched..
Mars
Mars
– Albert Einstein
– Albert Einstein
I'm at work currently and I don't know if the yeast is still sitting on top of the must I'll check that when I get home. Yes the must was steel before I pitch the yeast I let it settle after the vigorous stir.
I think things have started to change I just opened it up and looked at it and I think the fermentation has started. At least it smells like it has I've got a couple pictures one is before pitching and one is after. What do you guys think?
this is the after I couldn't get the before to download
OK got it fixed, this is before the yeast-
That surely looks like it's start fermenting.. by tomorrow there should be a heavy foam cap formed.. just leave alone and let the yeast do it thing..
Depending of the SG at start, check the SG in about 4 days and see where it's at..
Mars
Mars
– Albert Einstein
– Albert Einstein
