Over on the fruity goodness thread I had some requests about a recipe for a wine I make from time to time that I call Sugarplum Fairy
So here is a slightly revised version of that post.
Keep in mind that I violate a lot of normal wine making rules in the making of it or as I tell people, I do everything wrong but for some reason it works.
I don't think I would recommend Sugarplum Fairy if you have a limited number of plums...but then again that's what I had when I started making it but remember I do everything wrong and I'm told it shouldn't work but it does for me your results may vary and it's almost impossible to restart a stuck high sugar ferment.
Sugarplum Fairy came about as a mistake in the regular process I use for making plum dessert wine so to begin with it's best to cover the basics of how I make pretty much any dessert wine and talk about the differences.
When I started out my recipe was to take 1/2 to 3/4 of a bucket of pitted plums, depending on how heavy you want the wine. You could even use an entire bucket full if you like it very heavy. I often make 7 gallons of must so when I top up I am topping up with wine that is already fermented the same as the wine I am racking, although the wine in gallon jugs ferments much faster than in 5 gallon carboys. Right now I have numerous sizes of carboys ranging from 12, 7, 6 and 5 gallons plus an assortment of jugs that are both imperial and US gallons and 1/2 gallon so it's easy for me to start off in a 7 gallon carboy, rack to a 6, then to a 5. or start with 12, rack to both a six and five or pretty much any combination I need. My old method was to use a 5 gallon carboy and 2 imperial gallon jugs to start with. The reason for this is when I do plum wine I lose a lot in the process.
I only use fresh European plums for Sugarplum Fairy, there is a reason. If you use fresh European plums The final wine will finish golden or light pink with a lighter body. If you freeze and thaw the plums it will finish dark color, red or burgundy with more body, and probably more heavy plum flavor. In my case I find the yeast prefer the fresh plums but that isn't to say they don't like the previously frozen ones.
I don't use compden because my wife and I have adverse reactions to sulfites. I've never found the need to add DAP to plums but there is no reason it couldn't be added if you like although the sweet mead yeast I use for normal dessert wine does have a nutrient pack. I may or may not use Pectinase depending on my mood but it probably helps plum clear. I feel there are enough tannins in the plum skins to give the final wine balance so I don't add tannins either.
Boil enough sugar and water to make 3 gallons of simple syrup, this is just sugar and water with maybe a little bit of lemon juice or citric acid to invert the sugar. Pour the boiling water on the plums and mash them up. My inverted simple syrup contains as much sugar as the water will allow, it's something like 10lbs sugar. I like to bring the S.G. of the must up to around 14-16% potential alcohol (1.100- 1.120 S.G. or 24-26 brix). If I overshoot I have plain boiling water to adjust S.G.
Pour the boiling water on the plums and mash them up. Do this in a plastic bucket, or better yet stainless steel container NOT GLASS. Mash them with a potato masher or something like that, you can even just squeeze then by hand when you pit them if you like but DO NOT use an immersion blender because it will make the pulp so fine that it will be very difficult to strain and take forever to settle (ask me how I know ). I have a stainless steel stock pot I use for the hot water part. The reason for pouring the boiling water over the plums is to pasteurize them since I don't use compden. It might be worth noting that I live at 200ft above sea level which gets the sugar water as hot as possible without a pressure cooker so if you are at a high altitude you may not get quite as hot.
With Sugarplum Fairy I purposely boost the S.G. up to 21% potential alcohol (1.150 ish S.G., 33ish brix)
I then seal up the container as best as I can and let it cool. It wouldn't be a bad idea to force cool it but the temperature in my garage seldom gets above 60 and is usually in the 50s so I just set it on the cold concrete floor and wait overnight before pitching yeast. One thing you can do is purposely overshoot the S.G and use cold water or ice to bring the S.G. and temperature back down for pitching. Leave lots of head space in the primary because the must will try to escape while fermenting. I often split it into 2 primaries for a 5-7 gallon batch.
Once the must is down to temperature below 100f I aerate it by shaking or stirring the crap out of it them pitch the yeast.
My favorite yeast is actually Wyeast 4184 Sweet Mead yeast which as mentioned above comes with a nutrient pack but will only ferment to 11-12%.
Due to the high starting gravity Sugarplum Fairy uses EC-1118.
With Sweet Mead yeast I follow the directions on the package but with 1118 I just sprinkle the dry yeast on top of the must and let the yeast find their way in the world.
12hrs later I check on it, stir it up and seal or cover it. It's very important to have the primary properly vented because it will be making a lot of CO2. While in the primary I give it a gentle stir every 12hrs or so, once in the morning and once in the evening to keep the cap wet.
Eventually the cap settles and I strain it and transfer it to a carboy, make sure it is within an inch or two of the top and air lock it. If I'm making Sugarplum Fairy I leave it a little low and top it up with more simple syrup. Racking to a secondary usually takes place about a week after pitching the yeast but it needs to be before fermentation finishes but after the ferment is starting to settle down.
I then let it sit for 30 days then rack to a clean sanitized carboy, sometimes I re-rack after 2 weeks if there is a lot of sediment, then again at 30 days and do the same every 30 days after until it is clear and ready to bottle.
Each time I rack for regular dessert wine I top up with wine that is in one of the 2 gallon jugs because I start with 7 gallons. With Sugarplum Fairy I top up with simple syrup. Be aware that Sugarplum Fairy tasted dreadful right up to the point you are ready to give up and pour it out and then it suddenly magically changes. In my case this usually takes 4 months but it takes as long as it takes. By this time the yeast have given up and the alcohol level is down to around 18%.
Once the wine is clear and I deem it ready to bottle I sample it and adjust the sugar level to my taste, which is as sweet as a good expensive icewine, there is no set S.G., I just do it by taste, more correctly Mrs. Cranky does it by taste because she is the decider. I then let it sit another 2 weeks to a month just to make sure it isn't going to start re-fermenting, then bottle.
It's best to let it sit in the bottles for at least 2 months after bottling because the wine needs to adjust to the bottle and will taste off for the first month or two. Keep an eye on them to make sure fermentation doesn't restart and start pushing out corks or blowing up bottle but I have never had this problem with plums only blueberry. Blueberry likes to start re-fermenting after bottling, I've left blueberry in a carboy a full year after back sweetening before bottling and still wound up with fizzy wine...it tasted great but it was fizzy
I posted it in the thread but someone asked if I could post it somewhere more easily found than buried in a lengthy thread like the fruity goodness thread so I though this is probably the place to do that.Sugarplum Fairy dessert wine
- cranky
Re: Sugarplum Fairy dessert wine
It's that time of year again when fruit is on my mind and this year I scored some very nice plums but not enough to make brandy out of so I decided to make Sugarplum Fairy wine and lead everybody through my process in real time
I originally posted this in the fruity goodness thread but I think this is the best place to post about it for the next few months.
So to begin with here is what I posted over there
Warning: in this post everything I do in the process of making a wine is wrong! Don't do this yourself and don't think it's a good idea to ferment this way, because it's a very bad idea but for some reason it works for me
Sunday I stopped at a tree I had permission to pick plums off of and picked a bucket of plums.
Monday I took my bucket of plums to work and washed and sorted them. Any that had begun to split at the bottom were showing signs of mold starting so I wound up cutting away the moldy bits, which didn't amount to too much. I then decided I would use these to make another batch of Sugarplum Fairy wine.
Even though I removed any sign of mold I decided that because of it I would do a full pasteurization rather than just pouring boiling water over the plums. Fortunately we have a full kitchen at work and I had previously brought in a large stock pot. So I put the plums in the stock pot, added 1.5 gallons of water and heated the whole thing up to a simmer.
I think I should note that I would never bring apple juice up to this temperature since it changes the flavor but these are plums and for Sugarplum Fairy wine it's fine.
I then let it cool a bit and put it in a sanitized bucket. When I got home I dug out one of my sugar storage bins and boiled up some simple syrup consisting of 10#s of sugar and enough water to make it wet. I then added that to the plums. Then I got the left over skins and some of the pulp from plums we processed to make jelly out of (but haven't made jelly with yet) I added some sugar to that and heated it up as well to dissolve the sugar and pasteurize it and added that.
When it all cooled down I aerated it by pouring it back and forth between two buckets then split half in one bucket, half in the other and pitched some 1118 yeast. If you're wondering how high the S.G. is...well it's crazy high...so high I would never ever even think about fermenting if I hadn't had such success with it in the past and would certainly never try to make a distilling wash this sweet. When I pitched the yeast the must was 30 brix, which is about 1.129 S.G. or 19% potential alcohol. Now I will note that actual sugar plums reach a brix of 28+ so this is actually not out of line but 1118 is the only yeast I know of that can handle that high of a gravity. In the past I've actually been able to get to 21% alcohol using this same method.
It is worth noting that Sugarplum Fairy is a long term commitment. If I managed to get everything right it will ferment dry in 10 days but will be absolutely dreadful and undrinkable for the next 4-5 month when it will be repeatedly racked off the sediment and re-sweetened until the yeast finally give up and cleans up after the party then it magically comes around. It will still need to rest in the bottle for at least several months after that but in the past this has resulted in an absolutely superb high alcohol sweet dessert wine. My plan is to have it for summer sipping by the fire pit and Christmas gifts next year.
