Question about feed grade molasses
Re: Question about feed grade molasses
Glad to hear it turned out well for you. Hopefully I'll get a chance to start my wash in the next week or so. I'm curious to see if I get the floating sludge too. I really don't want to pay shipping for the good stuff either if it can be avoided.
Plain ole pot rig.
Stoutone did you ever try the deer feed molasses? Did you get it at TSC called Evolve? Its listed as pure cain molasses but has preservatives. Was thinking about grabbing it myself, so was wondering if you tried it.
I’ve used it. 82 brix, so it has a lot of sugar potential.Hillbillymike wrote: ↑Fri Nov 12, 2021 4:58 pm Stoutone did you ever try the deer feed molasses? Did you get it at TSC called Evolve? Its listed as pure cain molasses but has preservatives. Was thinking about grabbing it myself, so was wondering if you tried it.
But is also has a lot of oils. So, I’d recommend using not more than 1/2 gallon per 5 gallon ferment and supplement with sugar if you need more fermentables. But I don’t think you will.
Make a healthy starter rather than pitching dry yeast into the high gravity must. The yeast will do better and finish dryer for you. Also, because of the oils in the molly, it will foam heavily when beginning the ferment.
I had to triple distill the rum I made from the “deer lick” molly to get it to where I could drink it. Still, the molasses flavor was HUGE. And I even used the reflux column for the spirit run, taking the purity up to 190 proof.
In conclusion, the preservatives did not inhibit fermentation at all. But again, I made a yeast starter. Good luck.
How did you start your yeast? I usually take a little of the wash and pitch the yeast shake it up good in a separate container wait till it goes to work then ad to the wash.still_stirrin wrote: ↑Fri Nov 12, 2021 6:01 pmI’ve used it. 82 brix, so it has a lot of sugar potential.Hillbillymike wrote: ↑Fri Nov 12, 2021 4:58 pm Stoutone did you ever try the deer feed molasses? Did you get it at TSC called Evolve? Its listed as pure cain molasses but has preservatives. Was thinking about grabbing it myself, so was wondering if you tried it.
First, rehydrate dry yeast in a jar of warm water only, no sugar. The dry cell walls are fragile and if you put the yeast into a high sugar concentration, it can cause the cells to explode due to the osmotic pressure. The water will fill the cell and soften the brittle (dry) cell walls. This rehydration process takes only 20 to 30 minutes.
While the yeast is “coming back to life”, make a small sugar wash (a cup or two is enough) with an O.G. 1.030 to 1.040. If you heat the wash, it will help the sugar to dissolve better. But be sure to cool it to 100*F, or there about before adding the yeast.
Next, add the rehydrated yeast to the starter jar, gently mixing it (does not need to be vigorously stirred). Cover or use a stopper and airlock and set aside until your rum must is ready to pitch yeast. The starter will increase the cell count and generate more young, healthy cells getting ready for the molasses must.
When your rum must is ready, oxygenation will help the fermentation to start quickly. You can inject O2 (best) or stir vigorously with a paint stirrer (OK). Then, add the yeast starter and cover or add an airlock. Activity will start quickly, sometimes in an hour or two. And be prepared for the foaming, as it is quite messy if blows out of your fermenter.
Thanks! Ive been doing it a little wrong, always willing to learn thanks. Always use to do it the old way and just pitch the yeast in the fermenter and let her rock. The back woods way is a little less refined. I have a couple products fermenting now that i hydrated the yeast before i pitched.
- Dancing4dan
That looks like a product sold through a chain store in Canada. I read the label in the store and chose corn instead.
Marcus Aurelius
Marcus Aurelius
This is “the stuff”. It’s a syrupy liquid. About $15USD per gallon.Dancing4dan wrote: ↑Sat Nov 13, 2021 8:09 am That looks like a product sold through a chain store in Canada. I read the label in the store and chose corn instead.
It is definitely fermentable, but very “full flavored”.
Yup thats the stuff. I'm gonna take it and a scratch grain and make a sweat feed whiskey. Probably try a Rum when the weather warms up.still_stirrin wrote: ↑Sat Nov 13, 2021 9:17 amThis is “the stuff”. It’s a syrupy liquid. About $15USD per gallon.Dancing4dan wrote: ↑Sat Nov 13, 2021 8:09 am That looks like a product sold through a chain store in Canada. I read the label in the store and chose corn instead.
77F23A99-1D3F-4729-97FC-14FE65934287.jpeg 5A7E0AFF-A007-4F92-99BE-40F1CBD5F46C.jpeg
Well, that’s outside of my experience, “sweetfeed” that is. I’d recommend going easy on the deer lick molly when making your grist. I don’t know how the oils in the molly will interact with the corn oils in your mixture.Hillbillymike wrote: ↑Sat Nov 13, 2021 10:07 amYup thats the stuff. I'm gonna take it and a scratch grain and make a sweat feed whiskey. Probably try a Rum when the weather warms up.
But, good luck with it.
I recently found a gallon of the Evolved molasses I had left in a closet. I’ve done a few runs with it, and it works well for me. I made a quasi-Pugirum with it, but didn’t have brown sugar. I mixed some white sugar with a little table molasses, some epsom salt, DAP, and starter. I used Lavlin D-47 yeast, and it’s happily bubbling, but not foaming.
