Grappa
Rivver
Grappa
Post by Rivver » Fri Sep 07, 2012 5:24 am
I just picked about 25 lbs of a hybrid norton grape the other day and I've got them in the freezer for now. Any suggestions? My brother uses them every year for some great wine, but I'm not much of a wine drinker.
They've got great sugar content to them, hardly any tartness at all. Anyone have a good basic recipe for some grappa other than whats posted?
Dnderhead
Re: Grappa
Post by Dnderhead » Fri Sep 07, 2012 6:44 am
are you set up for this? grappa is made much like wine only fermented on the skins,pulp,stems. then distilled same .so you need some way of keeping it from burning.
Rivver
Re: Grappa
Post by Rivver » Fri Sep 07, 2012 7:03 am
Ahhh, did not realize that, I had planned on filtering out the pulp and skins.
blind drunk
Re: Grappa
Post by blind drunk » Fri Sep 07, 2012 8:03 am
One thing you can do is make the wine as you would normally, then use the skins to make a second wine by adding sugar and water to an abv of say 8-10%. You can strip both and then do a spirit run with the combined low wines. It's technically not a grappa, but you can get some of the flavors associated with grappa, especially with the second wine's contribution. The flavor of the skins can really come through this way and you also increase your yield. Don't go too high on the abv of the second wine or you'll ruin the whole thing.
I do all my own stunts
Dnderhead
Re: Grappa
Post by Dnderhead » Fri Sep 07, 2012 8:22 am
mite add...try to git the skins from making white wine.there will be more juice in them.
Rivver
Re: Grappa
Post by Rivver » Fri Sep 07, 2012 9:04 am
Thanks for the advice guys. Any idea how much sugar for a 25-30l wash, or should I shoot for a certain SG?
Dnderhead
Re: Grappa
Post by Dnderhead » Fri Sep 07, 2012 9:57 am
sugar is not usually added,but if you want, add a small amount.
the more sugar /water that you use the less flavor.
blind drunk
Re: Grappa
Post by blind drunk » Fri Sep 07, 2012 10:02 am
I wouldn't use any sugar in the wine wash and use enough sugar in the second wine to get about 8% abv.
All the calculators are on the Parent Site, so you may as well learn your way around -
http://homedistiller.org/calcs" onclick="window.open(this.href);return false;" rel="nofollow
Rivver
Re: Grappa
Post by Rivver » Fri Sep 07, 2012 10:06 am
Sounds good, and thanks again. I'll keep a post when I get things started.
