Pope's 10-plate Continuous Column
We don’t condone the use of Continuous Stripping stills as a method of running 24/7 as this is a commercial setup only .
Home distillers should never leave any still run unattended and Continuous strippers should not be operated for longer periods than a Batch stripping session would typically be run to minimise operator fatigue..
Re: Pope's 10-plate Continuous Column
stevea wrote: Sun Dec 19, 2021 3:33 pm
LWTCS wrote: Tue Mar 10, 2020 1:56 pm 20200310_145943.jpg
This plate is known to successfully process 350 gallons of beer per hour.
Uhhm - rules of thumb are ~ 1 - 1.3 l/hr feed per cm^2 (stripper). I can't see the scale, but I have a strong suspicion that you aren't vaguely close to 350gal/hr or 40cm ~= 16inch diameter! Yes you *could* run a 1500 l/hr, or more thru a 10cm diameter stripper ... IF you are willing to toss most of your EtOH. So I find this VERY hard to understand..
Dunno what to tell you.
Give Brent or Miles at Boundry Oak Distillery a ring and ask them about their grain in processing speed and get back to me.
230F at the beer effluent discharge. There is no alcohol at that temp.
And for the record, Pope's plate design can process 37 gph.
stevea
Post by stevea »
LWTCS wrote: Sun Dec 19, 2021 3:41 pm ....
I might do that. .... however. There is no liquid water at 230F below 2 bars pressure either - sorta meaningless w/o the pressure.
I mean you can have liquid 95%ABV at about 3 bars and 230F - right ?
37gph and 5" diameter is about right. At 4" (iirc Popes design) he's ~50% above commercial stripper design feed rates.
He might try checking his stillage losses carefully.
Steve, you are not factoring in grain in solids are you?
Pope is not running that fast on the 4"
John Tucker at Black Ven distillery is.
And he has checked.
Where are you getting your practical information from Steve? Because there is definitely a discrepancy here with your assertions.
Have you talked to Stumpy yet?
stevea
Post by stevea »
LWTCS wrote: Thu Dec 30, 2021 7:29 am Steve, you are not factoring in grain in solids are you?
This is getting pretty far off-topic, but solids don't change the boiling point (they impact nucleation). Pure water boils at 100C = 212F at 1atm. If you add polar solute then you can increase the BP a little. Seawater boils at ~102.5C, ~216F, and that has a LOT more polar solute than normal stillage. Maple reportedly syrup boils at 219F and is a nearly saturated sugar solution. 220F for stillage is either a measurement error, or reported under pressure (~3psig would do it and you might acheive that at the bottom of some stills), or some very strange stillage.
We are talking about an effluent stream that contains solids at the base of a beer column that is outfitted with live steam injection,,,at the base of the beer column. Think porridge.
Because of the amount of solids and the violent activity, not all of the steam gets condensed as the effluent exits the beer column.
