Continuous Stipper Build
Re: Continuous Stipper Build
You sure have my interest. We need a continuous stripper, but its commercial and I am just trying to learn from everyone that has tried.
I don't have an opinion on what you have there as I don't understand why every other plate is a different diameter?
Dish plates are more of a semicircle no?
Should work like the baffle tray pic in the link.LWTCS wrote:I don't have an opinion on what you have there as I don't understand why every other plate is a different diameter?
http://seperationtechnology.com/wp-cont ... 5/Dual.png
I don't see any way for vapor to be introduced below a liquid bed? How does this system promote/optimize phase change beyond what gets flashed at the injection sight?
I'm going to start with this is not my idea, it was found in some old distilling text. The transfer happens between the plates (I did say inefficient).
I can't see see vapor bubbling up through any of the liquid beds. Though I can see (theoretically) the brute force of enough heat flashing a bit of alcohol down the length of the column I suppose?
Well. If doesn't work well enough, drilling some holes and adding a downcomer wouldn't take much effort.
Sure. Really a good way to improve upon a point of view.
You could say that you're taking a bullet for the team.
Either way, your work looks tidy.
Sounds logicalGetsmokin wrote: ↑Fri May 08, 2020 9:27 amPlan was for a plate that could handle solids well. My understanding that dish and donut plates are pretty inefficient, I was hoping to get around that a little bit by increasing the surface area and adding more plates. Probably didn't answer your question..LWTCS wrote:Can you talk a bit more about your thoughts on the plate design?
How may plates does that thing have.
So I am only really counting the donut plates (I may be incorrect with this mindset) with 16 at the moment, so with the dish plates 32. I have enough to do 40 total. On 4" spacing.shadylane wrote:Sounds logicalGetsmokin wrote: ↑Fri May 08, 2020 9:27 amPlan was for a plate that could handle solids well. My understanding that dish and donut plates are pretty inefficient, I was hoping to get around that a little bit by increasing the surface area and adding more plates. Probably didn't answer your question..LWTCS wrote:Can you talk a bit more about your thoughts on the plate design?
Larry , as I understand them , there isn’t a fluid bed as such .
There is a fluid waterfall . ... a 360° waterfall from plate to plate as it cascades down . The vapour blows through the waterfall as it moves up .This is where the exchange occurs.
How a constant 360° sheet of liquid happens is where I have a hard job imagining. In my mind there would always be “gaps” that the vapour would blast through a the path of least resistance . And that would negate any exchange o that plate .
That's just about the way I imagin it happening too Yummy.Yummyrum wrote: ↑Fri May 08, 2020 2:38 pm Larry , as I understand them , there isn’t a fluid bed as such .
I had to look up "Disk and donut trays"
They not only exist, their used for what Getsmokin is wanting to do.
Quote
Disk and Donut Trays
This is another un-perforated baffle-type tray with large area for liquid down flow for use in low-efficiency and highly fouling applications. As the product name implies, the trays alternate in disk and donut shapes. In these trays the vapor passes through a curtain of liquid instead of typical intimate contact on the tray deck
Quote
I’d imagine that keeping it dead level would be mandatory .
Perhaps a slurry works better in these than a thin wash in regards to maintaining an even curtain .
I can absolutely see how these are best at not "fouling" (clogging).
Guess we'll have to see how much (if any) alcohol makes it down the drain? Certainly is an easy solution with respect to fabrication.
One thing thats always intrigued me about these is how close the plates are . When you look at a 4” perf plate , you are looking at 4- 6” min Spacing and it would seem up around 10” if you want to push it hard , yet all the pics of these donut plates have what would seem much closer spacing , perhaps 2” .
So I’m wondering if the entrainment issues are lower in these plate styles .
Id love to see that glasser running, a beautiful stack of continuous booze waterfalls, add a bit of mood lighting, maybe a saxophone in the background, one sexy beast
I would say definitely yes. There really isn't going to be any pressure at all because there isn't going to be any liquid hold up beyond the time it takes for a given amount of beer to plop on and roll off the plate.Yummyrum wrote: ↑Sat May 09, 2020 12:23 am One thing thats always intrigued me about these is how close the plates are . When you look at a 4” perf plate , you are looking at 4- 6” min Spacing and it would seem up around 10” if you want to push it hard , yet all the pics of these donut plates have what would seem much closer spacing , perhaps 2” .
Hey man, as long as the alcohol flashes before it goes down the drain. Is all that matters.
Fouling wise, seems like throughput speeds would be crazy fast. But I would think a certain amount of requisite dwell time would be necessary because of the inefficient nature of the plates. Running really fast would have to have a bunch more heat I would think? And more heat often means less separation ( lower abv).
Got the steam port/ tower base section put together.
GetSmokin what are the plate spacing?
At the moment big and little plates are on 2" spacing.LWTCS wrote:GetSmokin what are the plate spacing?
Nothing to exciting here..
New PC Parts. tube in a tube in a tube
Pc Assembled. Can honestly say that massively sucked to weld!
Possibly. I believe I have vapor and cooling in different places. Vapor inside center tube and outside tube #2.The Baker wrote:Tube in a tube in a tube: a Davies condenser?
Most of the column. Pump on the way...
On the Disk and donut trays
I think there's more happening than just the vapor blowing through the reflux water fall
Maybe the vapor is also heating the plates from below and when the reflux falls on the hot plate, some of it boils
In my mind there is more going on than a waterfall as well. Like Shady said heated plates and lots of terbulance is what I imagine, not so much waterfalls. But I haven't fired it up yet to see myself.
