All Bran Recipe
Re: All Bran Recipe
Postby acfixer69 » Sat Jan 13, 2018 7:03 pm
still_stirrin wrote:If it ain’t broke....don’t fix it.
that's what goose said somewhere eh
AC
acfixer69
Re: All Bran Recipe
Postby rgreen2002 » Sat Jan 13, 2018 7:12 pm
The bran also acts as a buffer to help prevent the pH crash frequently seen in sugar washes. It's a great recipe and makes a good neutral!
HD Glossary - Open this
rgreen2002
Re: All Bran Recipe
Postby still_stirrin » Sat Jan 13, 2018 7:34 pm
courtofjest wrote:I'm relatively new here, but I was making the all bran recipe and noticed that there are not any enzymes to break down the carbs in the wash. Would it help to add some malted barley to aid in breaking it down into sugars or is all-bran processed enough so that it does not matter?
Correct. This is a sugar wash recipe. The bran provides nutrients as stated, as well as buffering to the acid production as the ferment progresses. This too has been explained previously in this thread and as pointed out by RedwoodHillbilly, ACfixer, and rgreen.
The all bran recipe is an excellent base for a neutral, not particularly suited for a whiskey. But, it DOES make an excellent base for a gin...when you get to that recipe in the T&T.
UJSSM is better for that target (whiskey/bourbon), even though it too is a sugar wash (not a grain mash). Since these sugar washes utilize the sugar as the fermentable material, you don’t need enzymes to convert starches to sugars. Any grains added are for flavoring the sugar wash alone, not for potential alcohol.
Another is Odin’s corn flakes sugar wash recipe too. Corny flavor, but the alcohol comes from the sugar, not the cereal.
I hope you understand this difference (in the recipes). It is fundamental to your knowledge base in the hobby. Trying to make the all bran into something that it isn’t will lead to frustration and cause you to question your processes.
What is a Proof & Traille hydrometer: Alcohol-meter
Enzyme info: SebStar
HD Google search info: HD Google-how to
All about mashing grains: Braukaiser
Master Distiller
Re: All Bran Recipe
Postby rgreen2002 » Sun Jan 14, 2018 5:25 am
still_stirrin wrote:I hope you understand this difference (in the recipes). It is fundamental to your knowledge base in the hobby. Trying to make the all bran into something that it isn’t will lead to frustration and cause you to question your processes.
+100.... this is a KEY copncept. Repeated failure because of something impossible will drive you out of the hobby. This would be akin to trying to change lead into gold...over and over and over again with the unexpected result of it not working... :mrgreen:
rgreen2002
Re: All Bran Recipe
Postby Spriit Tisler » Wed Jan 17, 2018 12:47 pm
Fancy, I had all bran going on for 7 full days now and it's still going on. It has always been done&cleared before. I quess it's the temperature. Does it hurt to let it sit for another week, because I've got a job related trip in few days and I'll be back at next wednesday?
Spriit Tisler
Re: All Bran Recipe
Postby still_stirrin » Wed Jan 17, 2018 6:50 pm
Spriit Tisler wrote:Fancy, I had all bran going on for 7 full days now and it's still going on. It has always been done&cleared before. I quess it's the temperature. Does it hurt to let it sit for another week, because I've got a job related trip in few days and I'll be back at next wednesday?
Won’t hurt it at all. Just keep it under airlock. Have a safe trip.
Master Distiller
Re: All Bran Recipe
Postby artooks » Fri Jan 19, 2018 2:22 pm
What is your OG ?
artooks
Re: All Bran Recipe
Postby courtofjest » Fri Jan 19, 2018 3:20 pm
I did actually up the bran ratio quite a bit, added pearl barley, a bit of corn meal, and then converted a fair bit of sugar with malted barley. I added sugar to bring the gravity up and fermented to 1.0 before distilling in a pot still. The flavor actually came through very nicely and I'm quite pleased with it.
Looks like I absolutely made it into something it is not (without realizing its true purpose as a sugar wash) and it worked well for me luckily.
I'll give the original recipe a try next, I've heard it turns out great by many people.
courtofjest
Re: All Bran Recipe
Postby Spriit Tisler » Tue Jan 23, 2018 3:34 pm
My longer-than-usual batch was well finished and I stripped it. I though added some leftovers from liquor and punch and I got total of 8 liters of strippings that have somewhat around 60% abv. I did not bother to run lower than 35% or 97C though. Gonna spirit it tomorrow if I've got the time and meanwhile I put in 5g/l of sodium carbonate in there to compress the heads and tails, hoping to get max hearts out of it.
EDIT Spirit ran it today, and it all got down to 2.5 liters of pure hearts at 95ABV which appears to have very neutral odor, with hints of ethanol and very distant aroma off all-bran. From 8 liters of 60% I distilled total of about 4 liters, which of hearts was collected about 55%, discarding two extra 150ml glasses just in case. During all the distillation it sat tight at 78.6C which is corrected to 78.2 from barometer count, and only at the end slowly rised to 78.7, and then jumped to 79.6 for a moment and then began the swing from 79 to 82 at when tails kicked in and I stopped.
I need to refine some of my equipment and work habits for smoother operation. Need to weld a new valve outlet to bottom of my boiler to eliminate the need to move that piece of junk for emptying and cleaning. I also broke my most expensive 4-liter boiling flask which set me back for 200 bucks. :evil:
Next week it shall be the corn whiskey.
BTW, I added about third of a kilo of rolled oats (the porridge stuff) to the all-bran wash, because I feel it adds smoothness to the end product.
Spriit Tisler
Re: All Bran Recipe
Postby dee_stiller » Thu Feb 22, 2018 12:12 am
Another thread completed and noted. A must try recipe. In absentia, thanks very much Rad.
All this readings giving me a headache. Upside? At least the grog wont.
dee_stiller
Previous
Return to Tried and True Recipes
Who is online
Users browsing this forum: No registered users and 2 guests
