Do Hydrometers lose accuracy?
Opdog
Post by Opdog »
I have two proof and tralle alcoholmeters that I bought from Brewhaus. I bought one years ago when I first got started and another one I bought recently when I broke my hygrometer and thought I should probably have an extra on hand just in case.
I’m about to proof down some high test to put in a barrel and was double checking the ABV that I wrote on the bottle to make sure that the dilution was correct. I used the old alcoholmeter and the numbers were consistently 5% lower on an uncorrected basis. I thought that maybe the temp was significantly different. I’m doing the measurement at my basement bar, which stays at a pretty consistent 68F. I grabbed the new meter and it measured dead on the number I wrote on the bottles. So one of them is off.
I took a gallon of distilled water that I’m using to dilute my spirit and both meters measure accurate at zero. How do I figure out which one is off? It is only about 5% but I’d still like to have confidence that my measurements are accurate.
I don’t have any store bought vodka on hand to do a reference check there at the moment.
Any thoughts or advice is welcome.
I've stopped fighting my inner demons. We are on the same side now.
This topic has 23 more replies
Register Login
