I'm new to distilation, so forgive me if I'm not entirely up to speed with things that seem obvious - that said, I think I've understood the worst of it and just want a little clarity on bits and bobs. Feel free to point out where I'm being a moron - it happens, and I'd rather be thought of as ignorant but willing to learn rather than stupid.
First off, If I'm running a 30L (6.5 gal, or so) keg as a still, would one 3000 watt immersion heater suffice? It's 220V, if that makes any difference.
I could go up to a 50L keg, but when I'm brewing, I normally make 23L batches of different things, although I could make two batches of the same and stuff it in the 50L... Yeah, back on topic, would that heater suffice for the 30L? Would it suffice for the 50L? On top of that, how far from the bottom of the keg does the heater need to be? I've seen in a couple of posts about it being too close to the bottom and things scorching, but never the actual measurements for that to not really be an issue.
I'm making a CCVM, which seems to be going well. Getting a couple of meters of 2" copper pipe in the next couple of days & found a spool of 8mm copper piping that should be all good (it was 10m for £15. I was well happy). I'm pretty sure that that'll be all good for the double helix condenser, and I'll probably find out in a couple of days when I go to build it. Wish me luck. And salt. Lots of salt. How densely packed should the pipe be? I know I'm meant to fill the pipe with some type of copper scrubby, or perhaps lava rocks, or steel scrubbies (steel wool work? Think I know where to get a 20 pack of those for a fiver...meh, as long as it's stainless.)
Then the shotgun condenser - one question here, most designs seem to be 2" outer jacket, and 4-5 inner tubes which are about 9-10mm (3/8th of an inch or so?) My question here is, should I use the 8mm pipe I have? Gonna have a lot left over from the reflux condensor, so I may as well use it. I'm pretty sure I'd want a 5th inner tube if I used the 8mm piping instead of the normal 4, but north, south, east, west, center seems pretty easy to bash out.
Another question just popped to mind on the shotgun condensor, the baffles - 90 degree turns on 4 baffles should be fine, right? Or do ya go first, 180 degrees, 90, then 180. What works best? Yes this is probably a daft question but still something I'd like to know more about, is there a best way to do it?
And for the very last question (aren't you glad I'm shutting up now? Heh.) Not even really a question, more of a, I'm thinking of making a 2 inch drain at the bottom and raising the still up a couple inches. Solder in a 90 degree elbow, a valve and a small pipe and should be sweet, eh? Any recommendations on making what I've mentioned on the drain, or elsewhere?
Sorry for the wall of text, everyone! I'll appreciate any response, even if it's "Up your google-fu." Heh
Vic
