electric element
Pikluk
electric element
Post by Pikluk »
finally got my hands on a keg :) (almost crying of joy)
looking at half coupling and stuff
from what i read 1 inch is what i need to screw in a element?
but im looking around a bit "not much yet" and i see 17 inch long element
my keg does 14" width
more search found one for 14" tank
http://www.amazon.com/Better-Water-Heat ... 27&sr=1-17" onclick="window.open(this.href);return false;" rel="nofollow
but its 1-3/8" dia. flange?
where can i find in canada element to fit in a 14" wide keg?
most element use 1 inch right?
any tip on choosing an element?
The more you read the more you learn.
The more you learn the more you realize you don't know shit :)
olddog
Re: electric element
Post by olddog »
I use a 2400w solar water heater boost element, the element is copper in a sickle shape. It works well with my Flute and I don't need a regulator. :D
OD
Pikluk
Post by Pikluk »
did you get that online?
i tried searching "2400w solar water heater boost element"
got me nowhere
olddog
Post by olddog »
Pikluk wrote:did you get that online?
No I bought it from the local plumbers merchant
I found some on line search for " 2400w water heater element"
http://www.ebay.com.au/itm/HOT-WATER-EL ... 0665785961" onclick="window.open(this.href);return false;" rel="nofollow
OD
Pikluk
Post by Pikluk »
well thats from australia its not to be fitted on a half coupling "its a square flange" and its 17" long.
i need something for canada that will fit in a 14" keg.
thx tho ill take anything :)
olddog
Post by olddog »
I can send you one if you wish, the sickle style are a lot shorter because of the curve, mine cost $40, I would not have a clue what postage would be, it still has the 4 bolt fitting which I prefer as you don't have to get a fitting welded on the keg, just drill 4 holes and bolt it up with SS bolts. :D
Here you go, its $15 cheaper than I paid :cry: http://www.ebay.com.au/itm/2-4-Kw-Rheem ... 0314229399" onclick="window.open(this.href);return false;" rel="nofollow
OD
timmsy
Post by timmsy »
Hay mate here is another link for a brew shop here in Adelaide. I know he will ship but not sure the cost
http://www.beerbelly.com.au/burners.html" onclick="window.open(this.href);return false;" rel="nofollow
Dnderhead
Post by Dnderhead »
is see you have home depot..they should have them..they do make some that are "folded"
Pikluk
Post by Pikluk »
with the square flange dont you need bolts inside because i dont want to cut the top of the keg open
i want to use tri-clamp.
if i want to weld half coupling on i should get 1 inch fitting right? for regular water heater element.
Pikluk
Post by Pikluk »
what about the type like chrome plated and stuff which kind?
HookLine
Post by HookLine »
Get a low density, Incoloy coated element. Sickle shaped if possible, or you can use 2 lower power elements.
Be safe.
Be discreet.
And have fun.
Pikluk
Post by Pikluk »
im sorry if i ask a lot of question but the nearest homedeot or alike is 45min drive thats 1 and a half hour ride id like to know what im looking for.
Incoloy coated element is that like a standard thing or should the package say so?
what do they look like?
HookLine
Post by HookLine »
Incoloy elements are pretty common here in Australia. Most electrical trade suppliers will have them in stock or can easily order them in.
Should say on the packet if it is Incoloy.
Incoloy is a kind of stainless steel, pretty tough. Lasts much longer than zinc coated or plain copper elements. It is a dull grey colour, sometimes darkish.
It is well worth the effort to find one, especially a low density one.
Be safe.
Be discreet.
And have fun.
MuleKicker
Post by MuleKicker »
Pikluk wrote:with the square flange dont you need bolts inside because i dont want to cut the top of the keg open
good idea
Pikluk wrote: if i want to weld half coupling on i should get 1 inch fitting right? for regular water heater element.
yes, 1" pipe thread. http://www.plumbingsupply.com/images/st ... upling.jpg
or buy one of shinner's triclamp caps. It is already tapped out to accept a standard water heater element. Then all ya need is a stainless furrel to weld to the keg.
-Control Freak-
AKA MulekickerHDbrownNose
Pikluk
Post by Pikluk »
thanks a lot hook i think i seen those in kettles at least i know what to look for,
and mule that was a question dont you need to put bolt inside for the square flange type?
or is it enough to drill a hole tap it and screw the bolt?
unmodified keg user cooking on propane how do you guys empty your kegs ?
siphon? or just flip it upside down?
i work in my basment no floor drain have to carry stuff to the first floor for drain
so goin without a drain is not wanted.
if i want a drain i guess i need to see a welder so guess ill get the threaded fitting for element has well.
didnt get the fitting yet still looking for best way to go :)
Prairiepiss
Post by Prairiepiss »
If I were to do it again. I would put the drain on the bottom. Not the side. And I will probably do that next chance I get.
