Long length of distill time
I am running a 13 gallon boiler and my distill times seem unusually long. I did a stripping run yesterday and it took just over 7 hours from start to finish. My column is ~24 tall, starts at 2" and reduces to 1.5" at the very top, I did this to use the liebeg condenser that came with my original 8 gallon boiler. I ran the temp up to ~180 and had a steady stream coming out, left it there and the temp increased as the % dropped in the wash, I collected about 2.5 gallons at ~120 proof. I assumed the run would take 2 to 3 hours once I was at temp, it was almost double that.
My spirit runs are also very long, up to this point I have done them "non-stripped". I will do my first tomorrow using 2 stripped runs. My reflux column is 54", starts at 2", then reduces to 1.5" for the last 10" for the same reason. I pack with copper mesh and use CM to control vapor temp and (2 cross fitted tubes in the very upper portion, 10" above the mesh), and achieve 186 proof (again this was on first runs, not stripped runs). BUT, it takes 10 to 12 hours including heat up time.
I use propane and regulate the heat based on the temperature gauge in the pot and monitor the temperature gauge at the top of the column (liebeg attaches just above).
Could the reduction of the column be the culprit in causing long distillation times? I am flirting with the idea of making a new 3" pot still column with it's own soldered in home made liebeg. If that works I may modify my 2" reflux column to remove the reduction also.
Thanks for any help/thoughts.
Re: Long length of distill time
My friend you have committed the sin of temperature control.
That thermometer is a decoration and a thing to watch while it dances around. No more.
Your wash is a mixture that will boil and provide vapor at whatever the hell temperature it wants.
Your job for an efficient distillation is to have a pencil-lead size stream coming out of the spout. Damn whatever temp where that happens.
You'll grow old distilling by temperature and be too weak to drink it.
Here's a good read: http://homedistiller.org/theory/theory
Let's cut your stilling time down!
Thanks for the feedback fizzix. My stream was a "solid pencil lead" size during the duration of the run. I tested the % and it started around 140 proof and I stopped keeping it at 80 proof (turned cloudy, well into the tails during the stripping run). I might simply be impatient.
I do not have my copper column insulated, doing another stripping run tonight and I am going to add this insulation to see if it impacts. The area where I am working is around 60 degrees, I assume this could cause vapor to condense on the column and give a small reflux affect.
Good glad to hear that. You kept saying TEMPERATURE and I had to jump your ass!
I insulated my column and got better purity, Didn't really knock down time.
Let's see what the veterans say. Keep on, pal!
You are not the first in my life to jump my ass, lol. We all need one of them occasionally.
I have done 8 or 9 runs without stripping with good results (186 proof - very clean). My problem is that all my friends and the guys that work for me love my vodka so much that I have a hard time keeping any for myself. So I decided to ferment twice, do stripping runs, then I will do my spirit run Sunday and should dilute down to 4 to 5 gallons.
I will keep on - stubborn that way. Ok veterans, what about column diameter? I know I have an acceptable length (don't ask my wife though )for purity, is the diameter significantly affecting my vapor volume/speed?
As to your last question, yes. A larger diameter columnn should allow faster distillation. But if you were just less generous.....
i think your times are in line. i run a 4" column and a 15 gl pot and my time runs around 2-2.5 hours for a stripping run from the time i turn on my heat.
post your still pics here
http://homedistiller.org/forum/viewtopi ... 16&t=66917
- rgreen2002
To your question on column diameter: Column Diameter Properties within Reflux Still's
Also.. since you pack your reflux column... here is some good info about HETP: HETP properties in Reflux Still's (Theoretical Plates)
Insulating your column will allow you to retain heat and theoretically decrease the amount of energy/heat lost in the system but as for reflux.... not so much. Especially not more than your packed CM still.
When you do your runs what specific type of still do you run? Is it a pot still to strip and a reflux to spirit?
HD Glossary - Open this
As for your stripping runs, you’ve gotten some good advice. Don’t run your pot by temperature. Crank up the heat and let it rip. As long as your Liebig can keep up, run it as hard as it can. There’s no advantage on a stripping run to running slow.
Your column being 2-1.5” is good but how big is your Liebig? That may be your limitation.
I run a keg with 2” all the way to the 2” shotgun and can easily strip 12 gallons-ish within 3-4 hours from cold wash to finish. That’s with running down until my low wines average about 30%.
Also, for flavored product, like whiskey or rum, I would recommend running lower than 40% (80 proof). You’re leaving a lot of alcohol and flavor in the tank if you stop there. Obviously, it’ll take longer, though..
SR
SR
rgreen2002 wrote:To your question on column diameter: Column Diameter Properties within Reflux Still's
Yes, I do a pot still for strip and reflux for spirit. I read both of the links previously and picked up a bit from that, I believe it might be the size of the liebeg.
Did my spirit run today, averaged just over 1 hour per 1/2 gallon at 184 proof and I believe you may be correct about the liebig. It is internally reduced less than the 1 3/4", I measured and it has a top (from the column) opening of 3/4". I am going to strip the reductions off and make my own Liebig 2", then reduce at the 45 down turn and see what happens.ShineRunner wrote:As for your stripping runs, you’ve gotten some good advice. Don’t run your pot by temperature. Crank up the heat and let it rip. As long as your Liebig can keep up, run it as hard as it can. There’s no advantage on a stripping run to running slow.
SR
- raketemensch
You also haven’t mentioned what you’re putting into it for heat.
I personally don’t do stripping/spirit runs, but is the pencil lead-sized stream required for stripping? I was under the impression that for stripping you could just crank it as high as your product condenser can handle...
For heat I am using a propane burner, for the stripping run I took the boiler temp to 190 and maintained there, then let it elevate naturally as it distilled.raketemensch wrote:You also haven’t mentioned what you’re putting into it for heat.
Same for spirit runs, but I take the temp to 180 then control my vapor temp (measured inline just before the Liebig) with my CM (2 tubes through the top of the column with a needle valve for precise control of water flow).
After doing the s stripping then the spirit run I have almost come to the conclusion to not do stripping runs for spirits. My past spirit runs have been >182 proof and although they take more "tending", the time differential is not that great.
And the pencil sized stream was for the stripping runs. For spirit I get a broken drip/stream.
Youre doing it wrong.
Stop thinking about temperature and think about energy. A pot of water boiling on a nuclear reactor is the same temperature as a pot of boiling water boiling over a candle. The rate it is boiled off at is based on power input, not temperature.
There is nothing wrong with your still for stripping, you are just trying to drive it with the brake pedal instead of the accelerator.
For stripping runs don't bother using your CM tubes and just crank as much flame to the pot as your condenser can handle.
Of course some people like single runs with a reflux still, so that is a personal call. I used to make flavored spirits in a reflux still, but find double pot still runs to be faster and more productive and more repeatable in flavor.
Yeah for stripping just run the heat as high as you can, stop looking at thermometers. As long as your spirit isn't coming out the spout hot, your good.
Swedish Pride wrote:
I am using a pot still (not my reflux column with CM) for stripping runs. I didn't add more heat as my condenser was heating up and as I said above in the thread, I now believe this is the main issue I am having with the length of the runs. I am going to build a new condenser from the column and add length - the condenser I have been using came from my 8 gallon pot with a 1 1/2" column. I believe it is to small for me to push any more vapors through it. I will update once I run with the new liebig. Thanks for your input.zapata wrote:Youre doing it wrong.
Ok, here is where I am going:
Eliminate the 2" to 1.5" necked down portion on both my reflux CM column
Eliminate the 2" to 1.5 necked down portion on my pot still column
Eliminate the current necked down (3/4" opening) Liebig, it is also short ~12"
Getting a 2" x 17" 5 tube shotgun condenser
Making the reflux column 2" all the way to the shotgun
Making the pot still 2" all the way to the shotgun
Decided to just make it all the way it should be and eliminate all the BS trying to use that small liebig. Parts inbound, will give feedback.
- rgreen2002
Welcome to the wonderful world of Home Distillation! We're glad you're here!
Silly side note use % not proof. I'm surprised you're only getting 93% Column at 54" is a nice tall column. Should get about 95 to 96. Combination of no insulation, possibly running spirit run to fast or not allowing enough stabilizing time before taking of product perhaps? Also why use CM it's the hardest to run and get right especially using propane as you have two things to get wrong. A simple boka head on top of the two inch column is a much better idea. You can buy a double wound cooling coil online, I know one guy in New Zealand making them, and there may be others. If you're worried about speeding don't think 10 hours using scrubbers is excessive for spirits run, research SPP far lower HEPT so purity is high but can be run about four times faster than scrubbers. https://youtube.com/watch?v=W5W9YIP5fvo" onclick="window.open(this.href);return false;" rel="nofollow they are expensive so that may put you off
In comparison, it takes my still a good 8 hours to strip 10 gallons. I use a 13 gal pot, 2'x2" riser, into a .75" Lyne arm, and a 42" (length) Liebig condenser.
13.5g/50L keg
26g 4" stripping still
5500watts of fury
5500watts of fury
no reason a 2" won't do 4LPH on a stripping run on a decent condensor. turn your cooling water on full flow and turn the heat up until the distillate is coming out warm.
you can go much deeper than 80 proof (like down to 20 proof) this should amount to about 20% of your still charge in low wines at about 38% abv don't worry about cloudy or oils on the strip run...it will provide the flavour for the spirit run
in other words:
10 gallons of 7-8% wash in a 13 gallon still should produce 2 gallons of low wines at 38%abv in about 2 hours from the onset of production. a propane burner should be able to bring it up to operating temps in 45 minutes without scorching anything.
in other words:
now i drink for evil.
Hey Booze pipe, whatcha using for a heat source? I've got a still almost identical to yours except I neck down to 1/2" for the lyne arm and liebig. Stripping runs take nowhere near that long for me. Unless you're doing it on purpose I don't see anything that could cause that rig to be so slow other than a weak heat source.
For stripping, crank the heat as high as you can. That is, run fast as you can without alcohol vapors coming out of your liebig. If running flavored spirits, you're not drinking the low wines (except maybe a taste of the hearts here and there), take it down to 10-15% out of the liebig. If stripping for neutral, there is still good alcohol in the tails of a strip, just not as deep as flavored spirits.
- jonnys_spirit
When I run my 13g boiler for stripping a 1.070 ferment (about 9% ABV) charged with 11 or 12 so gallons I can almost fill up a 5g carboy with low wines running down to 0%. I take 200-300ml for fores and then run it slowish to get some headspace into the still to prevent puking then i'll crank it as much as my condenser can knock it down and still not puke which is almost full on 5k5W... I'll also degas and clear the wort which prevents foaming and scorch potential allowing me to run it harder and faster..
I originally had a 1" x 22"(?) jacketed liebig that came with the still that I replaced with one I built 3/4" (jacket) x 36" x 1/2" (product path) and implemented the wire spiral in the jacket and it made a ton of difference. I also stick a short coper wire spiral with a little copper scrubbie into the product tube to prevent huffing and surging..
-j
-j
I use the Bayou beer Brewer propane burner. It's been a while since I've fermented and stripped anything. Maybe I was doing it wrong! Initially, I had an undersized Liebig. I rebuilt it to be 42" in length .5" inner vapor, Jacketed by .75". Its very efficient now.zapata wrote:Hey Booze pipe, whatcha using for a heat source? I've got a still almost identical to yours except I neck down to 1/2" for the lyne arm and liebig. Stripping runs take nowhere near that long for me. Unless you're doing it on purpose I don't see anything that could cause that rig to be so slow other than a weak heat source.
Whenever I get back up and running I'll try to be less timid in cranking it up.
13.5g/50L keg
5500watts of fury
5500watts of fury
Ok, new column build is done, vinegar run is done, sacrificial run is done (used 1 gallon of heads at 170 proof plus 1.25 gallons at 120 proof with 6 gallons of water - collected ~1.5 gallons through the still then discarded). Now I need to run my stock of beard oil down so I can have a reason to give the column it's maiden voyage. Ended up with 34" of column for packing, then the sight glass, then 12" for CM, also added a 17" x 2" shotgun condenser. The 1.5 gallons on the sacrificial run came off in just under 2 hours (once heated), so although I had no packing, it appears my distill time will drop. We shall see.
Ok, here is my pot still finally posted. I made it all modular so I can share components for the column version.
And here is the column version. My packing area is 2" X 34", with a sight glass, then a cooling tube (coil inside), then a 2" shotgun condenser. The boiler is 13 gallons and I get ~ 185 proof on neutrals. Yes, I know there are easier to run and build options, but experimenting with the build based on what I read here and learn on my own is a big part of the fun for me.
Last run (this past weekend) went pretty well. Run time was less than 3 hours for each of the 2 stripping runs, then around 8 hours for the spirit run. The spirit run could have been shorter, but I played with the cooling to bring the fores and heads off very slowly, after a solid hour of reflux equilibrium. Once my jars (quarts filled ~2/3 full) cleaned up I sped it up a bit and was getting 3 jars (again 2/3 full) off an hour at ~185 proof. Allowed the cuts to air out in the jars lightly covered with cheese cloth for 24 hours, then selected yesterday. Diluted with distilled water to 100 proof, will allow to rest 4 days, then charcoal filter to polish, although this may not be necessary. Then I will bring down to 80 proof and NOT be as generous with my friends as I have been in the past.
A question for you, bbbark....what is the reason for insulating the outside of your product condensers?
It seems the objective would be to remove heat from the system in the water jacket, which surrounds the vapor tube. The shell of the heat exchange would approach the temperature of the water (especially since it is copper). Insulating will tend to hold the heat inside the condenser, which could cause it to heat up during the run.
Of course, if the jacket gets dangerously hot, then insulation would somewhat protect you from injury if you happened to touch it. But, I typically do on purpose so I can get a sense of the heat progression inside the condenser. It’ll be cool near the product outlet and warm near the vapor inlet. It gives me a good (qualitative) indication of the temperature gradient inside the condenser.
I just don’t understand why you did it.
Insulating the boiler and the vapor risers will help to stabilize the processes and even help conserve energy. But the product condenser....???
