I have an 8 gallon milk can still with a heating element towards the bottom. Getting ready to run my first 5 gallons of mash (corn maize and malted barley). My question is if it makes sense to add maybe a gallon or so of water to the pot to bring the total volume to 6 gallons. Given you can not run the mash below element, I was thinking if I add water it might allow me to squeeze out some more product before it gets below the element. I know this will lower my ABV, but ultimately the total amount of alcohol will be the same. Assuming the last gallon cannot be ran due to being below the element, I'd rather run 5/6 of the mash instead of 4/5 of it. Does this make sense or does it simply not work that way?
Thanks in advance.
Add water to mash for still with element?
Re: Add water to mash for still with element?
Better than guessing, try this: https://homedistiller.org/calcs/rad14701" onclick="window.open(this.href);return false;" rel="nofollowWithOrWithoutU2 wrote:I have an 8 gallon milk can still with a heating element towards the bottom. Getting ready to run my first 5 gallons of mash (corn maize and malted barley). My question is if it makes sense to add maybe a gallon or so of water to the pot to bring the total volume to 6 gallons. Given you can not run the mash below element, I was thinking if I add water it might allow me to squeeze out some more product before it gets below the element. I know this will lower my ABV, but ultimately the total amount of alcohol will be the same. Assuming the last gallon cannot be ran due to being below the element, I'd rather run 5/6 of the mash instead of 4/5 of it. Does this make sense or does it simply not work that way?
Thanks in advance.
Look at the "Distillate to Water Calculator" on Rad's calcs page on the home site. If you know your ABV, you can quickly calculate how much you will collect and how much will remain in your boiler.
Otis
Do you know how high the liquid level must be to keep the element submerged? Add water a quart at a time and check when it is fully covered. That’ll be your minimum liquid level.
Then, the calculator Otis pointed you to will tell you whether or not you need to add any water. But you will need the ABV of the wash for the calculator. You do know what that is, right?
Thanks. Very helpful. And Damn..you all have some amazing resources. Some very smart and generous people have put in some time and energy into this forum! I seriously doubt I will ever have enough practical hands on knowledge to contribute back to others. But hopefully in time I will at least learn this site enough to help others find the resources/knowledge that others have contributed.OtisT wrote:Better than guessing, try this: https://homedistiller.org/calcs/rad14701" onclick="window.open(this.href);return false;" rel="nofollowWithOrWithoutU2 wrote:I have an 8 gallon milk can still with a heating element towards the bottom. Getting ready to run my first 5 gallons of mash (corn maize and malted barley). My question is if it makes sense to add maybe a gallon or so of water to the pot to bring the total volume to 6 gallons. Given you can not run the mash below element, I was thinking if I add water it might allow me to squeeze out some more product before it gets below the element. I know this will lower my ABV, but ultimately the total amount of alcohol will be the same. Assuming the last gallon cannot be ran due to being below the element, I'd rather run 5/6 of the mash instead of 4/5 of it. Does this make sense or does it simply not work that way?
Thanks in advance.
Otis
Yes sir. About 30 cups to cover the element. And my ABV is about 6.3%. So according to the calculator if 92% of distallet collected, there will be 73 cups water left over with about 5.4 cups of of alcohol collected. So no need to add water.still_stirrin wrote:Do you know how high the liquid level must be to keep the element submerged? Add water a quart at a time and check when it is fully covered. That’ll be your minimum liquid level.
BTW...5.4 cups of alcohol... . If, 1/3 of that is drinkable after cuts that is maybe 3 cups by the time I bring it down to 40% if I pot distill it. I just realized, this will have to be more of a labor of love than a labor of practicality. I knew that already, but not by how much. But in all honesty as long as it is good quality I don't care much. But it already has me second guessing not going with the 13 gallon tank and 3" column.
