Finally got my new still up and running!
It's a pot still with 50l keg boiler, 1000mm copper column and shotgun condenser. At some point I'm intending to add a reflux condenser so I can run as CM reflux.
Anyway, just ran a vinegar cleaning run today, everything ran pretty well except for a few leaks that can be fixed easily.
I tried running it for about 1.5 hours, to make sure everything was properly cleaned out - until the RCD blew in the switchboard. When I looked a bit closer, looks like the boiler had boiled dry past the element and the element burnt itself out.
I can easily replace the element, but I was wondering whether there was anything I can do to prevent it happening again? Or just make sure I start with a big enough batch? My element is about 50mm from the bottom of the boiler.
