Airlock pulled water through
LordMareck
Post by LordMareck » Wed Nov 25, 2020 1:50 am
Hey all,
I have a strange problem. I use a simple cup airlock. And for the first time. the airflow on a bucket reversed.
Pulling all the water out of the cup into the bucket.
I have done about 30 buckets before, never seen this.
Any advice on what causes this?
skinny_chef
Re: Airlock pulled water through
Post by skinny_chef » Wed Nov 25, 2020 3:29 am
If it's finished fermenting and or has cooled down it will suck air back in. I have had it happen plenty of times from brewing beer
Master Distiller
Post by still_stirrin » Wed Nov 25, 2020 3:36 am
Temperature changes.
Your wort/wash/beer was warm and cooled. When it did, the volume contracted ever so slightly. As a result, it created a slight vacuum in the headspace in the fermenter, causing the airlock fluid to be sucked back into the fermenter.
Hopefully, it was just water and not any type of sanitizer, like chlorine. Water won’t hurt the yeast, but chlorine could kill them. You could use some of your heads in the airlock, or just water (what I use).
Once the yeast get active, the expiring CO2 will once again create positive pressure and bubble out the airlock. So, just fill the airlock again and don’t worry.
I can’t believe you’ve never experienced this before, although maybe not to this extent. It’s happened to me countless times. And I have way more than 30 ferments experience.
LordMareck
Post by LordMareck » Wed Nov 25, 2020 5:32 am
Thanks so much guys, much appreciated.
jonnys_spirit
Post by jonnys_spirit » Wed Nov 25, 2020 5:42 am
I put a couple drops of red wine in my S style airlocks so I can see from across the room whether they’re trending positive or negative pressure.
-jonny
i make stuff i break stuff
water into whiskey into water
just getting started in home distilling - been drinking for decades
16g copper pot still, 10l alembic, and a column or two
rubberduck71
Post by rubberduck71 » Wed Nov 25, 2020 7:01 am
Or spray some StarSan to fill them. Some people use cheap vodka too. Both keep the fruit flies from hovering around. They love the smell of ferments...
Durhommer
Post by Durhommer » Wed Nov 25, 2020 7:04 am
I use water and starsan in mine
stillanoob
Post by stillanoob » Wed Nov 25, 2020 9:32 am
I use Listerine mouthwash. If it got sucked in I don't care, you can wash your mouth with it!
LordMareck
Post by LordMareck » Wed Nov 25, 2020 10:33 am
Think i will skip the Listerine, otherwise some great advise
Deplorable
Post by Deplorable » Wed Nov 25, 2020 11:34 am
There are only 2 things I put in my airlock when used, distilled water, and cheap vodka.
Use all your senses, and its not that hard. You just have to pay attention.
howie
Post by howie » Wed Nov 25, 2020 6:40 pm
there is no place for airlocks at my place, no room for airlocks either :)
containers have a no-rinse sanitizer in them.
Durhommer
Post by Durhommer » Wed Nov 25, 2020 8:01 pm
Nice beer fridge
howie
Post by howie » Thu Nov 26, 2020 8:49 am
on a different note
i just discovered something today, after a discussion on thermal stratification :wtf: (their words, not mine)
the heatband is usually on the middle shelf.
inkbird probe was showing the correct temp, but then i noticed that the bottom fermenter was nearly 2c lower than the top 2.
moved the heatband to fridge floor and now all fermenters are the same temp.
small things and that, saved myself the price of a fan, i thought i needed :)
Setsumi
Post by Setsumi » Thu Nov 26, 2020 10:57 am
my airlock is forgotten in the box of non esencial brewing parafinela. a loose fitting lid works just as well.
press https://homedistiller.org/forum/viewtopic.php?t=79008
twins viewtopic.php?f=50&t=80886
