I have a few runs under the belt and one thing I've noticed is that the fusel oil doesn't appear proof-wise at the same time in different runs. One run it was at 35%, another at 46%. Why is that?
Using a pot.
What Makes Tails Appear?
Re: What Makes Tails Appear?
could be a few reasons. ferment paramters. type of mash. starting abv. passive reflux by cooler temps on the column. variable take off rate. depth in the pot.
I'm sure there is more possibilities, those are the ones that come to mind at the moment.
now i drink for evil.
+1 to what HDNB said
Understand that fermentation is a chemically complex process which results in a solution of different compounds, all which will may react slightly differently depending on the exact conditions its processed. Many-Many-Many variables will result in small differences(usually) in the outcome.
E.g. if the PH of your ferment is out of band (for whatever reason) this may stress the yeast into producing a larger than average amount of other compounds which we call heads/tails. Without laboratory level detail its almost impossible to determine for sure the exact differences from run to run, but its not something you should worry about.
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
EXPAT
___________________
And there is one good reason why no one should try making cuts by ABV.
