Am looking to poss build my first copper pot still with thumper and worm. First issue I have is where might I find copper sheets for the build am in tri state wv/my/oh? 2nd issue and biggest if find help with the math to help layout the parts need to build it all on the sheet of copper? Hope understood my ?’s and thanks in advance
One other ? Would I be better of using my 15.5 gal keg I have if so can I still use a copper thumper and worm?
New copper still
Re: New copper still
Yes and better to use the keg. And do some research on a copper boiler if you don't know where copper sheet is then I'll bet cutting and fitting may be above your craftsmanship.
Yea the keg is a better choice imo. Get some 2 inch pipe, ferrules, and triclamps. You can use another keg as a thumper too. Plenty of designs including my own here on hd if you search
I would definitely use the keg you have as a boiler, buy a 7 gallon keg for a thump, buy some copper pipe from home
Depot or any hardware store and build yourself a reflux still or a nice column to the thump and then a Liebig off of the thump, make sure to put a ball valve drain on both kegs to make things easy.
- Twisted Brick
+1
Just to be a contrarian...
You can find the copper you need online. There are plans available by pintoshine that have the template for a pot still ready to print, no math required. I love my home made copper pot still, had a lot of fun making it and it works great. Copper is very forgiving and unless you are all thumbs then you can make a simple pot still. Here is a link to my build:
https://homedistiller.org/forum/viewtop ... 7#p7572807
If you want to practice before deciding to build a full still why not start with a copper funnel. I believe we have plans somewhere on the forum. This would allow you to build something useful and see if you want to tackle a larger project. You can usually find smaller used sheets on copper at a metal recycling yard.
Starting with a funnel is a great idea. I made a little container I guess I'd call it first. I wish I had found the article you linked Bushman, good starter project. A parrot might be another starter project. And yes, I like using my parrot for stripping runs. Lets not get into that. But working with copper is fun. Do you happen to have an oxy-acetylene torch? You can do with a regular torch too but the oxy-acetylene is better.
