What makes the final aged product different colours. Single malt has a brownish colour at 7 months. Alder smoked Barley (80% barley) has a light yellow colour at 5 months. My bourbon has a reddish and very dark colour at 3 months. The wood is all the same source so I would assume the grain makes the colour. The proof is the same for all while aging. I may have answered my own question but I alway wonder why these things happen.
Finished product color
Re: Finished product color
The colour comes from the wood. Different toast, char and volume will contribute different colours to the whisky.
Re: Colore prodotto finito
If the abv is the same and the type of wood is identical, is there the variable quantity of wood?
- jonnys_spirit
Interesting! Unless the char/toast/quantity/volume of wood/spirits and ABV is different i'd also expect the color to be very similar...
j
j
PoppaW,
As said above, it’s mostly about the wood type, wood treatment and time.
I made a few threads where I played around with various woods and treatments (toasts/char). I took lots of pictures that show how varying toast levels, char, and different woods look compared to each other. To see those pics, check out two of the threads I show in my signature below, Learning to toast and using Fruitwood for aging.
Otis
PS. That fruitwood thread also shows some oaked products as well.
Otis
Thanks for the info. The volume of wood is similar for the scotch and bourbon for the volume of product and those are close in colour. I checked my alder smoked and it looks like I was told to age it longer and used some once used wood so that makes sense. I will try to get a pic of the bourbon and single malt to compare. It looks like a big difference to me.
If you want to make a comparison, you have to eliminate as much as possible the variables: same wood, same quantity (weight), same abv, same quantity of alcohol. Only in this way will you get results from which to start.
