I made an all-grain enzyme corn mash. After I put in the SEBamyl and waited an hour or so, I took a hydrometer reading. It came up about 1.052, corrected for temp. So that's about 7% ABV. The wash tasted sweet. Fermented for a week down to 0.998 and I took a proofing hydrometer reading. It's indicating about 4% ABV.
What happened to my alcohol?
Lying Hydrometer
Lying Hydrometer
- ShineonCrazyDiamond
Re: Lying Hydrometer
Did you run the wash and get the alcohol out? Otherwise a proofing hydrometer will do you no good.
Shine on you crazy diamond."
A proofing hydrometer is no good if there are any solids in the wash. Only use the (OG-FG)*131.25 to calculate ABV. Save the proofing hydrometer for the resultant spirit out of the still.
OK, finally got to mixing the low wines and measuring the proof. Turns out the wash ended up at a little over 8% ABV.
I think that's fantastic conversion for all grain.
That's a good turnout.
