Can I add yeast to cold mash?
Zzzmaggie
Post by Zzzmaggie »
The pot I use to cook mash is not very big. Im hoping i could cook enough to fill my fermenter in two batches then add yeast once its all finished and in the bucket. Is this possible?
jonnys_spirit
Re: Can I add yeast to cold mash?
Post by jonnys_spirit »
Yes. You should check the temp range for the yeast you’re using and your mash temp when you add enzymes or malts. Usually 150*F for enzymes and malts and 85F for bakers yeast.
-j
Zzzmaggie
Post by Zzzmaggie »
I think that will help me work it out better, many thanks
howie
Post by howie »
as long as you bring the fermenter contents to at a suitable temp for the particular yeast it should be ok.
are you doing the mashes in the same day?
otherwise your biggest problem could be storing the mash, i got a bad infection just overnight recently(the mash, not me :) )
you can probably store hot wort/wash/mash in HDPE cubes, or something airtight.
Stonecutter
Post by Stonecutter »
-Thomas Paine
Demy
Post by Demy »
Of course, no problem to divide your mash.
