How long can yeast last in Ujssm
OklahomaShiner
Post by OklahomaShiner »
It’s been about 4 to 5 weeks since I’ve last ran some ujssm. My question is is the yeast in my fermenter still good? Can I go ahead and add my sugar and water to get the wash going again, is it best to start over or could/should I add more yeast to it? My fermenter has been air locked the entire time.
Re: How long can yeast last in Ujssm
OklahomaShiner wrote: Wed Oct 27, 2021 9:33 am It’s been about 4 to 5 weeks since I’ve last ran some ujssm. My question is is the yeast in my fermenter still good? <— Can you? Or, should you?
Chances are, the yeast is still viable. However, it likely is not healthy, meaning it probably won’t “kick off” quickly. Or, it may produce off flavors and bad ferment by-products.
Can I go ahead and add my sugar and water to get the wash going again, is it best to start over or could/should I add more yeast to it? <— Would it “break the bank” to buy fresh (dry) yeast? I certainly wouldn’t spend the time and money for sugar for a UJ ferment and “risk” unhealthy yeast simply because I didn’t want to buy more yeast. Do you gamble? Like to play “the ponies”?
My fermenter has been air locked the entire time. <— Well, that is goodness, at least.
Free advice: Don’t “cheap out” in your processes.
At the very least, pull a small culture of the yeast and make up a starter to re-energize the yeast. Grow it up to the size needed for your ferment. Mitigate risk before wasting sugar on a bad ferment.
OklahomaShiner
still_stirrin wrote: Wed Oct 27, 2021 9:50 am
Thanks for the advice, I wasn’t really sure. I have PLENTY of yeast on hand. I’ll take some out and add a little sugar to see what happens but I’ll most likely just start over.
tiramisu
Post by tiramisu »
Washing and propagating the yeast for a couple of days seems like the smart decision although you would not be the first to just add sugar and water, and it will probably work out. But, it might not. It is usually best just to avoid problems in the first place.
ThomasBrewer
Post by ThomasBrewer »
Investing in a stir plate is a great way to step up your yeast cultures as well.
