1.5 inch copper pipe off still
vanstill
Post by vanstill »
just a quick question i have an 18 gal copper still i would like to add a 6x 12 column then attach a 1.5 copper pipe from column to thumper then onto my shotgun condensor which is 2x24 eith five tubes inside. my question is should i use the 1.5 off the thumper into condensor or should j use smaller pipe.
BlueSasquatch
Re: 1.5 inch copper pipe off still
Post by BlueSasquatch »
You want as large of pipe as you can afford, through pretty much the entire process. IMO
But for a more specific answer, I wouldn't go smaller than 2" diameter, since your shotgun is 2" and most thumpers/kegs have 2" connections.
Photos of your rig, or more details, will help the quality of the answer you get.
