Worm condenser
Posted: Thu Apr 30, 2009 11:17 pm
by stillvodka
Just finished building my pot still condenser worm, it's 18ft of 15mm diameter copper pipe , the wound coil size is 200mm diameter , condenser stands up at 24'' high and have 3'' between coils, will sit in a 60 liters of water (Refuse Bin) , I will be doing 5 Gallon washes,
Do you recon this condenser worm will work OK, I keep thinking that I have the coils to close together, wont disperse the heat , there is about 10 coils in the worm.
I would really appreciate any adavice on this, I Had hells work winding this worm, I cant really open the coiles wider I have soldered support rails down the sides of the worm on every coil.
Re: Worm condenser
Posted: Thu Apr 30, 2009 11:44 pm
by olddog
I use the same type of water container for use with my leibig condenser on a 50ltr keg, I can get a full run with no worries.
Re: Worm condenser
Posted: Fri May 01, 2009 4:56 am
by Tater
Sounds good to me
Re: Worm condenser
Posted: Fri May 01, 2009 5:12 am
by rad14701
The air gap (water gap) between the coils shouldn't be all that critical... As long as all of the coils have a downward slope, and have enough gap for water to circulate trough, convection will do its job and maintain a cooling phase from top to bottom/bottom to top...
Re: Worm condenser
Posted: Fri May 01, 2009 7:14 am
by stillvodka
Excellent , thanks for that,
I poured the tiny trickle of water down through the worm, and waited ,thought to myself It's not going to come out the other end, then about 30 seconds later out it come , so there cant be any low spots in there , all should be OK.
Re: Worm condenser
Posted: Sat May 02, 2009 8:32 pm
by Hack
The coils in my run are about 1 1/2" inches apart in a six gallon bucket. The distillate always comes out cool. You should be fine.
Re: Worm condenser
Posted: Mon May 04, 2009 4:02 pm
by Little Lukie
Old timers like atleast 7 turns on their worm. I found when your done and ready to run,take a ball bearing small enough for your worm and let it go in it. Itshould run freely thru. That way you know there isn't any restrictions or coil raised too high
in the coil.
Re: Worm condenser
Posted: Tue May 05, 2009 12:54 am
by punkin
Little Lukie wrote:Old timers like atleast 7 turns on their worm. I found when your done and ready to run,take a ball bearing small enough for your worm and let it go in it. Itshould run freely thru. That way you know there isn't any restrictions or coil raised too high
in the coil.
Nice to see ya back posting again Lukie... how did all the other stuff go?
Stillin again. or just cruisin through?
Re: Worm condenser
Posted: Tue May 05, 2009 5:53 am
by rad14701
I'd presume that to be 7 turns for luck more than anything... Some of those old timers were pretty superstitious...
Re: Worm condenser
Posted: Tue May 05, 2009 8:52 am
by Little Lukie
Ihaven't fired up in awhile.Just laying low.You know this stuff gets in your blood.
Re: Worm condenser
Posted: Tue May 05, 2009 9:48 am
by violentblue
Little Lukie wrote:You know this stuff gets in your blood.
usually through the digetive tract.
Re: Worm condenser
Posted: Tue May 05, 2009 11:00 am
by punkin
Little Lukie wrote:Ihaven't fired up in awhile.Just laying low.You know this stuff gets in your blood.
Yep.
I'm out in the shed most afternoons, even when i'm not runnin, i'm doin somethin related.
HopeSheSettlesDownPunkin
Re: Worm condenser
Posted: Sat May 09, 2009 7:20 am
by Adverse Effects
dont know why you guys go so big
CLICK THE PIC
see my worm condencer on the right
its 4Mt of 12.5mm coiled to fit in the 60mm tube and the water flow i need to keep it cool is less than the thickness of a match stick
Re: Worm condenser
Posted: Mon Jun 01, 2009 1:12 am
by boingk
Sounds fine to me. Had an almost identical setup using 10~12ft of half inch pipe and sitting in a 60L plastic bin of water. From a cold start it got warm, but if you use some large blocks of ice this will help. I find soft drink or milk bottles work well, just cut away the plastic to let you get to the ice and let a few float in the water. I ended up going air-cooled because I find it more conveniant.
Cheers - boingk
Re: Worm condenser
Posted: Fri Jul 03, 2009 3:56 pm
by hallzy
G'day everyone, I used to run a pot still and I felt bad about all the water it was using so I made a worm condenser. I got a piece of 1/2" copper, 6 meters long and wound it round an oxy bottle. I cant remember what size, maybe 8". I found a 20 gallon steel drum and fitted it inside, brazing it in place. I used it like that for about 5 years only having to top it up before each run as a litre or two would evaporate. The top 1/3 of the drum would get quite warm during the run but the other 2/3 was stone cold. It saved a lot of water in the time I used it, so I didn't feel bad about drinking a lot.
Re: Worm condenser
Posted: Fri Jul 03, 2009 7:08 pm
by pumpman
I have 3/8 tubing with 4 coils at 8" diameter and about 3" between coils in a 5 gallon bucket. I could run 5 gallons fine but my boiler will only hold 3. So when I refill it I refill the bucket as well. I think it will work fine.
