a sub compact design submarine
Gonna start over and built an old school 25 gallon boiler sub still. been wanting to experiment with thumpers for quite some time now..So here we go..
Re: a sub compact design submarine
Thats a beaut.. are the sides only wood or is the wood covering metal sides, just for asethics? What kinda wood did you use?
HD forum, the best damn group of criminals and outlaws you'll ever meet.
ozone39; damn I'm glad you finally built something I can understand.
Wow that sure is nice.
........WHY?.....Because I can......
My 4 inch Hybrid 2 Stage Build. . .
The Cooling Tower Project
My 3" Valved Flute Build. . .
cob wrote:ozone39; damn I'm glad you finally built something I can understand.
- Danespirit
I was waiting for one of your rather unusual builds, Ozone.
That looks awesome..!
Nice job! Look really nice planned and built!
B
B
The sides are made of Douglass Fir (it was that or either white pine around these parts). I did a tongue and groove type joint where the 2 x 4's in both pieces where grooved 1/2" and then pounded in a 1/2" x 1" filler piece between the boards. I then wrapped them Jute twine (bees wax helped keep it in place) before I screwed the metal onto the side boards. There is no metal backer on them. Stainless all thread (double nut and washer) was used to keep the sides parallel and squared up to each other before I attached the sheet. That proved to be the most difficult part of the build. All in all it's been a lot of fun and it's good to get back to doing some woodworking. I'm very near being completed, a firebox and burner is next on the list. I appreciate all the great feedback...
I like the hell out of this.
Built a basic BBQ pipe burner...things are coming together..
I saw on another post about the new burners that you are still using this beauty. Did you ever have a problem with it? Did the Douglas fir put any off tastes into your drink?
The new burners really helped with scorching (way more even heat). The drilled out tubes I had in there before created a hot spot and would cause problems. The new burners and fire box (better venting and larger head space) solved that problem. I ran a 80% Rye/20% barley run last week flawlessly with no scorching of any kind. the pine boards did take some time and care to "break in". I soaked them for two weeks changing the water every two days (this also helped seal up the tank itself). I performed about 3 boil outs with just water and a tad of white vinegar and two sacrificial fermented sugar runs. The first run with wash had a hint of pine (was kina simular to a gin). By the end of the second run the off flavor had dissipated. Makes great some pretty smooth whiskey for sure. I put the tails from the previous run in the thumber barrel and it put's out between 160 and 140 proof (160 heads down to 155 ish) 150 to 140 proof is the g spot for the hearts, which I will run down to 60-50 proof for the tails for the next run in the thumper........
http://homedistiller.org/forum/viewtopi ... 86&t=57213
Nice build, I'm impressed.
Where you distilling on the grain ?
I've seen fir used throughout more than one commercial process. I wouldn't shy away from it, and think this example was beautifully done.
Wonder what sort of life expectancy the wood will have?
upon closer inspection I'm glad that's a new wax ring with the box. I don't even wanna think about a used one.
from start to finish I do everything from mashing to fermentation and distilling with out transferring....I installed air jets for mixing the mash and for initial heat up (to around 155 F) to aid in not scorching to the bottom.
- Danespirit
That's amazing, no scorching..i assume even with a lot of grain in it..?
When you empty the still, do you fill it with water to keep the wood moist and tight sealing or do you just put antother ferment in?
I keep it 3/4's full of water. Changing the water out once a week if it sits that long with out being run....My grain bill is generally 1 to 2 LBS of grain for every gallon of water..
It doesn't look like the OP has been active for awhile but this is an interesting build and was just wondering if anyone else has tried it.
A sub design has been used for really long time. I don't know the date of inception, but many decades. The first issue I see is it has to be filled with water, when not in use. You want the wood to stay sealed by absorbing the water and swelling. If you spring a leak, it could be laborious to seal. These are not multi generational stills. I don't see passing this down to a grandchild. The wood will not last forever.
Personally I would build this design before a keg. I prefer a more historical design over convenience of a keg. The build cost would be a fraction of a all copper build.
Most on here view a sub as a quantity over quality type still. Ultimately it's up to you to weigh the pros and cons.
My 9" Shotgun Condenser
This hobby really is not so much about making alcohol. But bottling opportunities to make memories with Friends and Family.
Get that sub an a pot. Put same beer in em and same cook an a blind taste test an get back to me.
Production beer is production beer
So I'm tole
So I'm tole
