What heating element would you use?
alohashine
Post by alohashine » Fri Jan 27, 2017 1:44 am
About to start a build for a keg pot still. I have a 15 gal stainless steel keg for a boiler, and a 5 gal keg I want to use as a thumper. What electric heating element would you recommend?
My current setup is a 6 gal copper Appalachian style still. I use a 1500w element that works fine. I know a lot of guys will say 4500w but I don't have access to the big outlet required for that. I'm thinking maybe drill 2 holes in the keg and using 2 elements to bring it up to boil, then cut back to 1 during the run?
Master Distiller
Re: What heating element would you use?
Post by NZChris » Fri Jan 27, 2017 2:26 am
Two 1500W elements give you the options of running at 3000W, 1500W and 750W, without having to use a controller, plus you can finish a run with a blown element.
Post by shadylane » Fri Jan 27, 2017 5:28 am
I'd recommend using these https://www.amazon.com/Camco-02933-Scre ... QCQSQNKSC4" onclick="window.open(this.href);return false;" rel="nofollow
Or this https://www.amazon.com/dp/B0183KIU1E/re ... B001RD7MK0" onclick="window.open(this.href);return false;" rel="nofollow
That way, the boiler can be run on 120 or 240V
What ever you choose, make sure it's made out of incoloy or SS and not zinc plated.
bluefish_dist
Post by bluefish_dist » Fri Jan 27, 2017 7:44 am
+1 on the camco stainless elements. They work well and camco even sells them for brewing applications. I use the 4500w on 110 for my fermenters and the 5500's in my stills and mash tun.
Formerly
Dsp-CO-20051
DFitz
Post by DFitz » Sun Jan 29, 2017 7:19 am
I've changed my elements out just recently.
http://www.brewhardware.com/product_p/e ... ple_tc.htm" onclick="window.open(this.href);return false;" rel="nofollow
alohashine
Post by alohashine » Mon Jan 30, 2017 2:15 am
NZChris wrote:Two 1500W elements give you the options of running at 3000W, 1500W and 750W, without having to use a controller, plus you can finish a run with a blown element.
How could I run at 750w without a controller?
Master Distiller
Post by NZChris » Mon Jan 30, 2017 2:33 am
Wire, or switch, two 1500Ws in series.
