Hi
Tell your opinion about this device https://prostill.co.uk/en_US/p/2-in-1-D ... ter-2T/305" onclick="window.open(this.href);return false;" rel="nofollow
Can those thumbers work,because those are so small?Looked that because i don't have lot of space and size matters....with that case,little is better
Can that one do the work?
Re: Can that one do the work?
We recommend the thumper to be larger, I don't run a thumper but believe the concensus is that it is about 1/3 to 1/2 the size of the boiler. I personally would not invest in that still.
i run two thumpers both are sixth barrels for my keg. general rule should be around a third. once you start running them if the thumper is to small it really doesnt work right. you can wind up with blow through and you really dont get that secondary boiling going on either. hope that helps
post your still pics here
http://homedistiller.org/forum/viewtopi ... 16&t=66917
- kiwi Bruce
I don't like this rig at all ! Look at the size of the lyne arm...what is that...1/4 inch ?
Getting hung up all day on smiles
That's not a serious thumper! Way too small and indeed a recipe for problems.
But it might be a slobberbox.
Ok i forgot that build,thanks for all answers How about that https://destylacja.com/pl/p/DESTYLATOR-MINI-11/17" onclick="window.open(this.href);return false;" rel="nofollow maybe not real pot because little internal reflux or that with little modify https://www.ebay.com/itm/25-Liters-Alco ... ZxIhZ.What" onclick="window.open(this.href);return false;" rel="nofollow happens if pot bottom is larger than hotplate?Takes more time what else?Pls comment those builds That is so easier if we got mirc or discord channel...I choose those because easyway to start, and if you doesn't wanna do that,you doesn't lose so much money.
